Rear Turn Signals.....Need some help - Victory Forums - Victory Motorcycle Forum
post #1 of 10 (permalink) Old 04-10-2013, 08:02 PM Thread Starter
HammerTime85's Avatar
Default Rear Turn Signals.....Need some help
I thought this was going to be a fairly straight forward job but something I am doing isn't right. I bought a universal type, non-led pair of turn signals to replace my stock rear turn signals. I assumed you could use the factory wiring and just remove the old turn signals and wire in the new ones. The factory turn signals come with two wires, a power and a ground I believe.
I installed the new turn signals. Wired them together and tested them out. Nothing happened. I thought maybe I had the wires backwards so I rewired them in reverse, still nothing. I thought maybe I had some bad turn signals. I ran a power feed right to them using my car battery, and they lit right up. The bike is a 2007 Hammer. Any suggestions?
2007 Hammer S
Santa Rosa Exhaust
Lloydz fuel controller w/ custom map
S&S intake
Ness goodies
HammerTime85 is offline
post #2 of 10 (permalink) Old 04-10-2013, 09:58 PM
CrossRoads's Avatar
Right side is wired backwards, but make sure you check the polarity before you connect the lights, or risk frying your ACM.
CrossRoads is offline
post #3 of 10 (permalink) Old 04-11-2013, 06:11 AM Thread Starter
Thanks Crossroads, I didn't notice the right side was wired backwards when I removed it. I will give it another shot tonight.
2007 Hammer S
Santa Rosa Exhaust
S&S intake
Ness goodies
post #4 of 10 (permalink) Old 04-11-2013, 07:03 AM
Betting your ACM is already fried. Once it's done backwards, that's pretty much it. They are hyper sensitive to shorts.
2011 Silver/black Vision, Ness Big Honkers, Ness Twin Sucker, PC-V w/AT, Lloydz VM1-DR cams, Lloydz Adj Intake, Lloydz Variable Timing Wheel.
2006 110" (133hp/142tq) +nitrous Kingpin (sold)
Gunslinger is offline
post #5 of 10 (permalink) Old 04-11-2013, 07:14 AM Thread Starter
I didn't try starting the bike after I tested the lights, but my front signal lights were still working if that means anything.
2007 Hammer S
Santa Rosa Exhaust
S&S intake
Ness goodies
post #6 of 10 (permalink) Old 04-11-2013, 07:20 AM
If both fronts work fine, then your ACM isn't fried... yet. But be very careful! For whatever reason, the front right turn signal is always wired backwards on the steel framed bikes. It's easy to see though if you just look at the wiring coming out of the headlight bucket. What lights are you putting on? You aren't going with LED's?
post #7 of 10 (permalink) Old 04-11-2013, 07:31 AM Thread Starter
You're making me nervous lol. These turn signals are going on the rear of the bike. Is it still going to be reversed on the rear? These are just a cheaper set from bikemaster until I decide to spend the money for the led rear.
2007 Hammer S
Santa Rosa Exhaust
S&S intake
Ness goodies
post #8 of 10 (permalink) Old 04-11-2013, 07:42 AM
No, the rears are not reversed. But as you noted, they are two wire lights. Are you putting on 3 wire (running light function) lights? If so, you run the low side to 'keyed' power source, such as the license plate light.
post #9 of 10 (permalink) Old 04-11-2013, 07:47 AM Thread Starter
Okay, thanks for the clarification Gunslinger. No these are 2 wire lights, like the OEM units. I am going to go buy some new electrical connectors and try reconnecting, maybe I am having a issue with a poor connection.
2007 Hammer S
Santa Rosa Exhaust
S&S intake
Ness goodies
post #10 of 10 (permalink) Old 04-11-2013, 08:34 AM
are they 10 watts if they are not they wont work.After market lights are normally like 20 watts universal they work on harley but not 2005 -2008 victory.Thats way they might not be working to much draw
hammer316 is offline
