Stage 1 Flash - Victory Forums - Victory Motorcycle Forum
post #1 of 4 (permalink) Old 04-13-2013, 10:32 AM Thread Starter
8BallHammer's Avatar
Default Stage 1 Flash
I got a great deal on some swept pipes, had them recoated and installed Thunder Monsters. The closest Vic dealer is about an hour away(mostly highway miles). Can I do the pipes,air filter, and unhook the O2 sensors and be safe riding it to the dealer for the reflash?
Has anybody ever checked A/F ratios with attached vs. unplugged O2 sensors??
2013 AF Green Crossed Country
TriOval slip ons
Lloydz VM-1 DR Cams
Lloydz PTS +4 degrees
PC V
Lloydz air filter
1/4 turn throttle
99.7 HP/107.2TQ
Now you know how I've felt for the last 8 years:D
8BallHammer is offline
post #2 of 4 (permalink) Old 04-13-2013, 12:55 PM
slickvic's Avatar
You will be safe. Ride it clean and take er nice n easy. You can even run her strong but dont beat her. Listen for upshift popping and decel backfiring. If you dont have either then turn around and go home. O2's disconnected right?
slickvic is offline
post #3 of 4 (permalink) Old 04-13-2013, 12:59 PM
bsbabcock's Avatar
Order a VFC III follow the guide and call it a day.
2013 Hard-Ball - Lloydz VM1-DR cams, air filter, timing wheel, PCV, properly tuned at KMC
Master, Biltmore Lodge #446, AF&AM
bsbabcock is offline
post #4 of 4 (permalink) Old 04-13-2013, 01:50 PM
You should be fine. All stage 1 does is in crease your rpm's by 500 and richen's up your fuel.
By disconnecting your 02's your have richened up your fuel.
Stage 1 will more then likely will not get rid off any popping.
