Forward control question - Victory Forums - Victory Motorcycle Forum
post #1 of 11 (permalink) Old 04-17-2013, 07:44 PM Thread Starter
8BallHammer's Avatar
Default Forward control question
I bought the Victory 2" forward kit for my 2012 Hammer 8 Ball and the shift rod seems too long.
The stock rod is 6 3/4".
The rod that came with the kit is 11"
I was wondering if anybody can tell me the length it should be.
I am thinking I should just cut 2" off of the end with right hand threads, and cut new threads.
Thanks in advance,
Dale
2013 AF Green Crossed Country
TriOval slip ons
Lloydz VM-1 DR Cams
Lloydz PTS +4 degrees
PC V
Lloydz air filter
1/4 turn throttle
99.7 HP/107.2TQ
Now you know how I've felt for the last 8 years:D
8BallHammer is offline
post #2 of 11 (permalink) Old 04-17-2013, 08:05 PM
lunaticrider's Avatar
It should be 2 inches longer than the stock shift rod. Just cut it down to fit. Let me guess you bought the kit from WD's? I made my own forward/riser kit and needed a new shift rod so I contacted them and he forwarded me to the guy that makes the kit for WD's and he tried to sell me a 11 inch shift rod, told him he was crazy anf it needed to be 8.75 to 9 inch in length....
2012 Hammer 8 Ball - All upgrades are listed in my Garage
If racing was outlawed ... Then only outlaws would race ...
lunaticrider is offline
post #3 of 11 (permalink) Old 04-17-2013, 09:03 PM Thread Starter
Actually bought it from the Vic dealer.
So... in essence. 2" forward = rod should be 2" longer than stock?
TriOval slip ons
Lloydz VM-1 DR Cams
PC V
Lloydz air filter
1/4 turn throttle
99.7 HP/107.2TQ
post #4 of 11 (permalink) Old 04-17-2013, 10:31 PM
Yes, will there be enough threads left the if you cut yours down?
post #5 of 11 (permalink) Old 04-18-2013, 12:18 AM
I may be wrong but it seems I heard somewhere that the 8 ball Hammer has the front pegs moved back(closer) to the rider than the standard or HammerS . This could be why your shift rod is shorter. I have an 07 Hammer and the shift rod on the forward relocation kit was 2 inches longer than stock. On my stock bike the front bolt of my peg mount was also used to tie the front of the frame together. I Hope this helps.
2007 Hammer
throttleking is offline
post #6 of 11 (permalink) Old 04-18-2013, 12:54 AM
Yes the 8 ball has the pegs 2 inches rearward and slightly lower than the "S" model, but it is not the location on the frame but rather the shape and angle of the whole unit itself. So +2 inches forward still adds up to 2 inches longer shift rod no matter how it's added up....
post #7 of 11 (permalink) Old 04-18-2013, 03:37 PM
I am not familiar with all the specs on the 8 Ball Hammers and thought maybe they moved the standard hammer footpegs with a rearward relocation kit that Vic offers instead of a peg mount redesign. Ignorance on my part.
2007 Hammer
post #8 of 11 (permalink) Old 04-19-2013, 10:29 AM
noSkills's Avatar
I got a 2" extension for my hammer and they sent me a link bar that was 4" longer. Seems they just can't get this product right. I ended up cutting my and recapping it.
2012 Hammer 8-Ball - Custom LED mods, Stabel Air horn, 2" front control extensions, x-bow exhaust.
noSkills is offline
post #9 of 11 (permalink) Old 04-19-2013, 10:36 AM
NOEMTZ's Avatar
Some bikes did come out with the "vegas low" or "high ball" set up....so some 2" forward extensions will be wrong. I guess the best thing to do is determine exactly what set up you have before ordering to reduce any confusion.
www.noemtz.com
NOEMTZ is offline
post #10 of 11 (permalink) Old 04-19-2013, 04:40 PM
JoeyB's Avatar
Hammer 8Balls do in fact come with pegs that are moved 2" back. If you only want to go 2 inches like I did you can buy a forward location kit for a vegas low(moves the pegs to the standard location). It doesn't list fitting the Hammer but it bolted right on
2011 Hammer 8 Ball
Hacker Rippers
PC V w autotune
Lloyds timing wheel
Ness Intake
MBW Rear LED's
MBW Plate Mount
JoeyB is offline
