Help - Victory Forums - Victory Motorcycle Forum
post #1 of 23 (permalink) Old 04-21-2013, 05:01 AM Thread Starter
Default Help
installed vm1 dr cams, torque tubes, IAV, PCV with map, thor on 2010 vegas.
Fitted new plugs rechecked elec conn,s front cylinder not firing, only rear cylinder. pump ok and primed and front spark plug sparking. Any ideas?
2010 Vegas 8 Ball
VM1 cams, TTI, IAV, PCV, Timing wheel, RPW Thor
glassback is offline
post #2 of 23 (permalink) Old 04-21-2013, 06:08 AM
PhilC64's Avatar
Recheck all of your electrical connections while using the manual. In particular check your fuel injector connection and ensure it is fully seated. You should hear it click. Once you've check all the connections, check them again. Let us know what happens.
2015 XCT - Flying lounge chair
PCV, ATS +4, Lloydz filter, VM1-HPT cams, and Freedom True Duals.
2004 King Pin - 100 cid Big Bore, Ness Intake, Victory Performance Exhaust
2010 XR - Road toy
PCV, ATS +4, Lloydz filter, VM1-DR cams, and Freedom True Duals - traded
Cam Swap write up for X Series bikes:
https://docs.google.com/open?id=0B95...YW1XVXFpeU9fUQ
PhilC64 is offline
post #3 of 23 (permalink) Old 04-21-2013, 07:47 AM
SilentUnicorn's Avatar
Can you do a compression check on that cylinder?
m
'12 Vegas, 78 Bonneville, 69 BSA project.
SilentUnicorn is offline
post #4 of 23 (permalink) Old 04-21-2013, 09:12 AM Thread Starter
Thanks for replies
I swapped rear cam first, TDC locking pin, loosened cam sprocket bolt,
remove pin rotate to access other cam sprocket bolt, remove cam bolt, rotate to TDC, lock, remove cam sprocket bolt, tensioner, sprocket and swap cams. Buttoned up cam cover on. Removed front cam cover, front TDC, lockin pin, loosen cam sprocket bolt, remove pin, rotate to access other cam sprocket bolt, remove bolt, TDC, lockin pin, remove bolt, sprocket, tensioner, swap cams, button up.
2010 Vegas 8 Ball
post #5 of 23 (permalink) Old 04-21-2013, 11:47 AM
First off take a meter and see if your getting power to the rear cylinder. Check plug wire with meter to see if its good.
Check all electrical connectors.
Most auto stores rent compression gauges
post #6 of 23 (permalink) Old 04-21-2013, 12:07 PM
Bad V V's Avatar
Rear cylinder works. Front doesn't. He has spark so wire is good. My guess is issue is fuel related. So I agree with PhilC, check the injector connector.
2003 Victory vegas
Bad V V is offline
post #7 of 23 (permalink) Old 04-21-2013, 12:25 PM
busajack's Avatar
Take the PCV out of the system and see what happens. If it does the same at least you know you its not the PCV. 30% failure rate on them things.
I have to grow old but I don't have to grow UP.thumb up. 2010 Jackpot.
busajack is offline
post #8 of 23 (permalink) Old 04-21-2013, 01:27 PM Thread Starter
Thanks
will take PCV out in morning and see what happens.
Keep you posted
2010 Vegas 8 Ball
post #9 of 23 (permalink) Old 04-23-2013, 05:49 AM Thread Starter
Re-connected all PCV, still the same.
Removed PCV put back to standard connections, still the same.
Gonna have a look at timing again
Let you know
2010 Vegas 8 Ball
post #10 of 23 (permalink) Old 04-24-2013, 11:38 AM
woodrow731's Avatar
Take the plug wires off and turn it over. Then pull the plug and see if it has fuel on it. If it has fuel on it. hook the plug wire back up to the front plug and ground the threads to the head or cylinder to see if it is firing. Then trouble shoot based on witch one is the problem. If both are working you need to recheck the timing on the front cylinder.
2010 vegas 8-ball
1 1/2 lowering kit
torque tubes,pc-v
vic performance pipe
109 big bore
s&s .495 cams
variable clutch
woodrow731 is offline
