Wiring for Trailer lights - Victory Forums - Victory Motorcycle Forum
 1Likes
post #1 of 22 (permalink) Old 04-22-2013, 06:46 AM Thread Starter
Squatch's Avatar
Default Wiring for Trailer lights
Anyone wired the XCT for a a Trailer? there has got to be a better place to pick up the wiring besides under the fender with the CB/ ABS, and other stuff there.
Squatch
USN/USCG Vet
2013 Cross Country Tour
Zumo 665 w/weather
Power Commander V
Lloydz Air filter
PTS set to +6*
Hydraulic Clutch
D&D wrapped/RPW baffles
Touring Cams
124 hp/119#ft
A country that forgets it's defenders, will itself soon be forgotten
Squatch is offline
post #2 of 22 (permalink) Old 04-22-2013, 09:09 AM
dtmmil's Avatar
One of the last posts in the show off your cross country posts has a guy with a trailer. Maybe ask him? What are you doing for a hitch and trailer? Im curious about doing it myself.
Sent from Motorcycle.com App
currently bikeless
2012 Cross Country(Imp blue)
Hawley MN(sold)
dtmmil is offline
post #3 of 22 (permalink) Old 04-22-2013, 09:59 AM Thread Starter
Squatch's Avatar
Bushtech hitch was a breeze to install.
However,
The wiring harness is a universal type from Electrical connection.. and it is reael busy in that rear fender.
Squatch
USN/USCG Vet
Zumo 665 w/weather
Power Commander V
Lloydz Air filter
PTS set to +6*
Hydraulic Clutch
Touring Cams
124 hp/119#ft
Squatch is offline
post #4 of 22 (permalink) Old 04-22-2013, 10:07 AM
Your XCT should have a four wire pigtail coming off of the rear harness, ready to connect to your trailer lights. No controller necessary.
2011 Silver/black Vision, Ness Big Honkers, Ness Twin Sucker, PC-V w/AT, Lloydz VM1-DR cams, Lloydz Adj Intake, Lloydz Variable Timing Wheel.
2006 110" (133hp/142tq) +nitrous Kingpin (sold)
Gunslinger is offline
post #5 of 22 (permalink) Old 04-22-2013, 10:18 AM
Buellx72's Avatar
Squatch,
I just finished a bushtec install on a XCT with an isolator. I also found that the wiring would have been a pain in the ass if I had to break into the factory harness. So I did a little research and came up with factory style connectors that I built a pig tail onto. Basically you reach under the rear fender and unplug the wiring harness that goes to the read tail light and turn signal assembly. Then you just plug this harness into both plugs that you just unplugged.
I have only built the one so far but it worked great! I purchased enough of these to make a bunch of the harnesses with the intention of selling them. Not trying to get rich here, just wanting to cover my parts and some of my time. I was thinking around $25 bucks for the harness. I have not got around to it yet but, if your interested, I can make one up.
Now you would still have to connect your wiring or isolator to the new harness. This can be done on the work bench, though. After that just plug it in. If your interested ill try to post some pics later today or tomorrow.
Bill
2012 Cross Country Tour Sunset Red
Lloydz air filter
PCV w/ AT
D&D wrapped pipes (unwrapped now)
2013 Vision Tour
'07 Road King Sold
'00 Buell X1 Sold
'72 Sportster (In Pieces)
Buellx72 is offline
post #6 of 22 (permalink) Old 04-22-2013, 03:27 PM
Buellx72's Avatar
Gunslinger,
I've seen you post this info before. I've also seen people say they couldn't find this on there bikes. I am in the latter category. I sure wish I was able to find this it would have made my life much easier!
Lloydz air filter
PCV w/ AT
2013 Vision Tour
'07 Road King Sold
'00 Buell X1 Sold
Buellx72 is offline
post #7 of 22 (permalink) Old 04-22-2013, 05:04 PM Thread Starter
Squatch's Avatar
I have found a couple empty single connectors, but not seen a 4 wire connector yet. Is this connector down by the ABS unit?
And is it a connector or just wires?
Thanks Rob.
Squatch
USN/USCG Vet
Zumo 665 w/weather
Power Commander V
Lloydz Air filter
PTS set to +6*
Hydraulic Clutch
Touring Cams
124 hp/119#ft
Squatch is offline
post #8 of 22 (permalink) Old 04-22-2013, 06:39 PM Thread Starter
Squatch's Avatar
Originally Posted by Buellx72 View Post
Squatch,
Bill
Bill,
PM sent. Love to get one of your custom Harnesses.
Cheers
Squatch
Squatch
USN/USCG Vet
Zumo 665 w/weather
Power Commander V
Lloydz Air filter
PTS set to +6*
Hydraulic Clutch
Touring Cams
124 hp/119#ft
Squatch is offline
post #9 of 22 (permalink) Old 04-22-2013, 06:43 PM Thread Starter
Squatch's Avatar
If it were a little less snowy I would make a run out your way.
Have family in Tinely Park
Cheers
Rob.
Squatch
USN/USCG Vet
Zumo 665 w/weather
Power Commander V
Lloydz Air filter
PTS set to +6*
Hydraulic Clutch
Touring Cams
124 hp/119#ft
Squatch is offline
post #10 of 22 (permalink) Old 04-22-2013, 07:01 PM
ronfox's Avatar
hey guys
sure would like to see some pics of these bikes. its been a whyle i was on her. but seen a lot of trailors this past weekend at bike event in angel city unadela ga.
thanks alot ron
SUPPORT YOUR LOCAL ABATE !!
KNIGHTS OF SOLOMON MC
HARRIS COUNTY, GA,
custom 1999 bobber
2012 cross country tour
sunset red
D&D slip on
16 inch ness apes
performance up grade ( cams, )
painted red inside fairin to match
(mods to come )
Its not really what you ride, but that you ride!
ronfox is offline
