Llyods ecu reflash review - Victory Forums - Victory Motorcycle Forum
post #1 of 9 (permalink) Old 04-27-2013, 06:50 PM Thread Starter
Default Llyods ecu reflash review
Kmc powersports just installed a Llodys reflashed ecu into my vegas. The power difference with the new fuel map alone is amazing let alone the increased redline. The s&s map in it previously was garbage compared to the way it runs now. Popping is gone after rollout and the third gear bog at 3k is eliminated. Pulls hard in every gear now no matter the rpm.
Highly recommend the ecu flash for anyone with cams. I still have my vfc ii in place for fine tuning but i don't seem to need much extra fuel beyond lloyds base map.
Anyone in the New England area I highly recommend giving Kyle a call at Kmc for any performance or maintenance needs.
07 Victory Vegas 8 Ball
Rpw Slash Pipes, S&S Intake, Lloydz VM-1 Cams, Lloydz VFCII, Lloydz extended rev ecm, 1/4 turn throttle, Oem Tach Kit, Hammer V Bars, Barnett clutch, Bullet Headlight with HID, Ness black retro derby covers, Black ISO grips, Mbw led front signals, Black Ness rad II mirrors.
jzales84 is offline
post #2 of 9 (permalink) Old 04-27-2013, 06:57 PM
lunaticrider's Avatar
If you don't mind me asking, what is the cost of the flash?
2012 Hammer 8 Ball - All upgrades are listed in my Garage
If racing was outlawed ... Then only outlaws would race ...
lunaticrider is offline
post #3 of 9 (permalink) Old 04-27-2013, 07:42 PM Thread Starter
I just swapped my ecu for a preflashed one which cost me $200. You can ship your ecu to llyods to have it done for the same cost I believe.
jzales84 is offline
post #4 of 9 (permalink) Old 04-28-2013, 10:51 PM
toejam's Avatar
ECU's or ECM's are vehicle specific, ie... they the contain pertinent info regarding that particular bike.
2013 Anti-Freeze Green XC
Vance & Hines Slip On's
BadBoy Horn, PCV
Gustafsson +4 Windscreen
Picasso Nano PN2.350D Amp
HMD520 Gorilla Bagger Bars
2010 XC 116 Big Bore - Gone
2006 Hammer - Gone
toejam is offline
post #5 of 9 (permalink) Old 04-29-2013, 05:28 AM
benm's Avatar
so is it not just rev extended ?
it is remapped as well?
did they turn off the decel fuel cut off?
if thats the case i'll send mine over there and get rid of the wiseco tune box
2012 vegas 8ball, k&n filter,
rpw thor, wiseco fuel control.
Torque tube intake,
Wilbers shock, gold valve emulators ,
Batwing ,cruise control.
benm is offline
post #6 of 9 (permalink) Old 04-29-2013, 06:51 AM Thread Starter
Correct the fuel map is tweaked as well as timing to maximize the benefit of cams. Seems to be spot on.. have to get it on the dyno to check the a/f ratios. You would still want some sort of fuel controller to fine tune it since every bike is different even with the same mods.
jzales84 is offline
post #7 of 9 (permalink) Old 04-29-2013, 09:42 AM Thread Starter
What kind of info do they contain?
jzales84 is offline
post #8 of 9 (permalink) Old 04-29-2013, 09:54 AM
toejam's Avatar
VIN # along with other info, what all I dont know.
Lloydz stopped doing swaps after they learned that the ECM's are specific to each bike.
BadBoy Horn, PCV
2006 Hammer - Gone
toejam is offline
post #9 of 9 (permalink) Old 04-29-2013, 08:43 PM Thread Starter
Oh well the dealer is the only one who can read that info and I don't ever plan on bringing my bike there lol. It spins the rear rolling in 1st which it could never do on the old tune so its a big difference in power.
jzales84 is offline
