Weird scenario, need help! - Victory Forums - Victory Motorcycle Forum
post #1 of 14 (permalink) Old 04-30-2013, 08:01 PM Thread Starter
Johnboy's Avatar
Default Weird scenario, need help!
Ok guys, I know all of you have had more than just a Victory in your lifetime, so here it goes. I got my wife a 2007 Yamaha V Star 650 to ride with me. It only has about 4000 miles on it. Previous owner had it for his wife and put Vance and Hines shorty pipes, k&n filter and had it jetted at the local dealer. This thing is running lean on the back carburetor and will not idle good until really warmed up, then once good and warm back fires violently on decel after a long run and will keep the rpms up around 2000 when she comes up to a stop after a long run, thus being leaned out until she blips the throttle a few times to fatten it up and let it settle down. The mechanic we have has called Vance and Hines and found she has the right jets for the pipes etc... Any ideas? At a loss here and she wants to ride. Maybe Kevin x is looking and may have astrole of genius here. I'll take any advise, but not a new bike yet, she's still learning.
2008 Kingpin
Black with white flames.
Arlen Ness Intake/Filter
Lloyds PFC III
Ness Mirrors
Victory Hard Bags
Green Neon
Johnboy is offline
post #2 of 14 (permalink) Old 04-30-2013, 08:04 PM
half_crazy's Avatar
If the bike spent a lot of time sitting ('07 with 4000 miles is 800 miles/year) the carbs are probably gummed up and the pilot jets are clogged.
2006 Victory Kingpin
half_crazy is offline
post #3 of 14 (permalink) Old 04-30-2013, 08:05 PM
CrossRoads's Avatar
When were the carb and jet needles cleaned last?
CrossRoads is offline
post #4 of 14 (permalink) Old 04-30-2013, 08:06 PM
Pretty sure that has an AIS check to see if it's been blocked off. If not start there after checking the jets/needle.
shanko is offline
post #5 of 14 (permalink) Old 04-30-2013, 08:09 PM
Could also be an air leak on the carb boot. Spray carb cleaner on the boots and see if the idle changes.
07 Victory Vegas 8 Ball
Rpw Slash Pipes, S&S Intake, Lloydz VM-1 Cams, Lloydz VFCII, Lloydz extended rev ecm, 1/4 turn throttle, Oem Tach Kit, Hammer V Bars, Barnett clutch, Bullet Headlight with HID, Ness black retro derby covers, Black ISO grips, Mbw led front signals, Black Ness rad II mirrors.
jzales84 is offline
post #6 of 14 (permalink) Old 04-30-2013, 08:13 PM
NJ8BALL's Avatar
Run some seafoam through it, if it's been sitting long time use a whole can of it in the tank or half can. After that tan of gas, change the oil. If it's carburetors you might to sync them up.
You can buy 1 or make your own with small diameter tubing and oil. Google homemade manometer.
'09 Kingpin 8-Ball...Sanded chrome exhaust, Stage 1 slipons, VFCIII, Lloyds IAV, Stonny's 27" sissybar, Edge bags with ghost brackets,Kuryakyn black ISO grips,
http://www.bluebeardimagery.com/
http://blue-beard-imagery.artistwebsites.com/
Photo equip: Canon 60D, Canon 55-250is, Canon 18-55, Canon 70-200f4,Tamron SP10-24
NJ8BALL is offline
post #7 of 14 (permalink) Old 04-30-2013, 08:36 PM Thread Starter
Johnboy's Avatar
We have been in the carbs and there is no gunk. Everything is clear. We have sprayed carb cleaner on the boot etc.. And even used a smoke machine, no leaks there. What is the AIS and its function? I'm about to go to a bigger jet. How about fuel pump? Or something else like that to block the rate of fuel? We just put on a new fuel filter and still the same result. Advise. The answer has to be under my nose.
2008 Kingpin
Lloyds PFC III
Ness Mirrors
Victory Hard Bags
Green Neon
Johnboy is offline
post #8 of 14 (permalink) Old 04-30-2013, 08:39 PM Thread Starter
Johnboy's Avatar
Sorry, left out that carbs are synchronized and measuring perfectly.
2008 Kingpin
Lloyds PFC III
Ness Mirrors
Victory Hard Bags
Green Neon
Johnboy is offline
post #9 of 14 (permalink) Old 04-30-2013, 08:47 PM
dtmmil's Avatar
Put the next size up pilot jet in, sync the carbs, disconnect the ais system(thats your decel popping) and check your plugs after that for jetting. Make sure your air filter is clean also. Yamahas are terribly lean on the pilot circuit, my wife has the same bike, still stock exhaust. I went up one on the pilot and now it starts real good and we dont have to leave the choke on forever anymore. I also removed the ais setup and synced the carbs, it runs really good.
Sent from Motorcycle.com App
currently bikeless
2012 Cross Country(Imp blue)
Hawley MN(sold)
dtmmil is offline
post #10 of 14 (permalink) Old 04-30-2013, 08:48 PM Thread Starter
Johnboy's Avatar
My mechanic called the guys at the Yamaha shop and their tech mentioned an internal vacuum leak. Not too sure how to take that. Any guesses? I'm with my mechanic because he is certified across the board, and happens to be the only victory certified tech in town, so I am keeping my friends close.
2008 Kingpin
Lloyds PFC III
Ness Mirrors
Victory Hard Bags
Green Neon
Johnboy is offline
