Crankacse Mounting Bolt Oil Seep and Low Fuel "Gurgle" - Victory Forums - Victory Motorcycle Forum
post #1 of 6 (permalink) Old 05-14-2013, 03:37 PM Thread Starter
Default Crankacse Mounting Bolt Oil Seep and Low Fuel "Gurgle"
Hi all. I have a 2006 Victory Vegas 8-Ball. I've got a couple issues and I was hoping someone could offer some insight.
First Issue:
Noticed some very slight oil seepage around one of the crankcase cover mounting bolts (top-middle bolt). I went to check the torque on the bolts and they didn't seem to be very tight. Not holy s**t loose, but not reassuringly tight either. I don't know the torque spec, but I gave them another half turn just in case. Either way, would this be a bad gasket or could this be caused by oil over-capacity? I performed an oil change recently and filled it to the capacity specified, however the stick indicates an oil level slightly above the "full" mark (when checking the oil after standing the bike up straight).
Second Issue:
I've started to notice a persistent "gurgling" noise. It only seems to happen when the fuel tank is less than 1/4 full, which makes me think it is a fuel venting/ pump issue. It starts and stops at random, lasts for a few seconds, and occurs regardless of gear position, idle, throttle, etc. On a recent inspection I noticed the throttle body adaptor appears to be cracked in various places. I know I should replace it either way, but could this be causing the gurgling noise? Kind of a long shot, but maybe I only notice it when my fuel tank is low since there is less sound dampening through the tank?
There are no other indications that anything else is wrong.
I really appreciate any thoughts, feedback, etc.!
curryjp is offline
post #2 of 6 (permalink) Old 05-15-2013, 09:38 AM
I can help with the torque specs. Send me a PM.
Every day is a good day to ride. Some days are just better than others.
2010 Cross Country
Vic Performance filter, D&D, ATW, VFC III
2006 Vegas (sold)
2003 Shadow 1100C (sold)
Various other bikes all the way back to 1968.
BCVR LC#35
rocketo is offline
post #3 of 6 (permalink) Old 05-15-2013, 11:37 AM
Oil change with filter put in 4qts start bike let it run till light goes out. Now wait a minuet then stand bike straight up and add you 1/4qt.
For the gas gurgling try opening caps when it does it and see if it stops. Check gas cap for venting. Vent might be blocked
post #4 of 6 (permalink) Old 05-15-2013, 11:40 AM
Any body that reads this
in your owners manual there is a page that will tell you tourq spec for the size bolt your looking at.
If you don't have a manual go here
http://www.purepolaris.com/en-us/Vic...rs-manual.aspx
post #5 of 6 (permalink) Old 05-15-2013, 11:45 AM
You may want to go ahead and change that throttle body rubber boot if it's showing cracks. It can/will cause your bike to run way too lean.
2007 Hammer
throttleking is offline
post #6 of 6 (permalink) Old 05-15-2013, 02:11 PM Thread Starter
Thanks for the help everyone
curryjp is offline
