Radial and Bias tires - Victory Forums - Victory Motorcycle Forum
 1Likes
post #1 of 16 (permalink) Old 07-30-2013, 07:46 AM Thread Starter
ridinman's Avatar
Default Radial and Bias tires
I'm not a tire expert so I wonder what the benefit is to putting a bias ply tire on the front and a radial on the back.
The Hard ball was that way, now the XR 8 ball is that way, but the XC 8 ball has radial both front and rear.
All my bikes have been either, but not mixed. What's the benefit? The $$ isn't that much different.
Ride Safe, Ride Often
Life's to short to be GRUMPY
Bill
2014 XCT
Lenexa, KS
ridinman is offline
post #2 of 16 (permalink) Old 07-30-2013, 07:54 AM
saddlebag's Avatar
My guess is they had an issue running a radial E3 with a tube on the spoked front rim on the HB and LE. Don't see a lot of radials on spoked wheel bikes, though they use the E3 on the rear of those bikes.
If you believe everything you read on the internet, mixing up tires like that is a recipe for instant death, but I haven't seen any recalls on those bikes or the Triumph Speedmaster which runs a bias ply on the rear and a radial up front.
Anyway, I think it's a typo. Their webpage is a cluster right now. Hopefully, it will improve over time. Every picture of the XR 8 ball shows it running an E3 up front.
2011 Cross Roads
saddlebag is offline
post #3 of 16 (permalink) Old 07-30-2013, 10:00 AM
half_crazy's Avatar
Radial rear and bias front is OK.
Radial front and bias rear is a no no...
2006 Victory Kingpin
half_crazy is offline
post #4 of 16 (permalink) Old 07-30-2013, 10:07 AM
saddlebag's Avatar
Because...
http://www.triumphmotorcycles.com/mo...eedmaster/2838
Tire Front 100/90 - R19
Rear 170/80 B15
2011 Cross Roads
post #5 of 16 (permalink) Old 07-30-2013, 10:34 AM Thread Starter
ridinman's Avatar
You are correct, all the pics show an E3. The E3 does come in a bias, but the website says its an Elite II, not a E3. The tread patterns are totally different.
Bill
2014 XCT
Lenexa, KS
ridinman is offline
post #6 of 16 (permalink) Old 07-30-2013, 12:08 PM
half_crazy's Avatar
Because...
Tire Front 100/90R-19
Tire Rear: 170/80B-15
Metzeler Catalog Quote:
IMPORTANT NOTE REGARDING TIRE UPGRADES
Mixing radial rear tires and bias ply front tires is allowed only when fitting the proper custom width wheels for the tire application. (see application chart) OR when fitted by a custom manufacturer (i.e. American Ironhorse).
FITTING RADIAL FRONT TIRES IN COMBINATION WITH BIAS PLY REAR TIRES
IS NEVER ALLOWED!
post #7 of 16 (permalink) Old 07-30-2013, 12:29 PM
depot picker's Avatar
I've heard those warnings since radials were first introduced, but I've never heard anyone actually have a problem.
depot picker is offline
post #8 of 16 (permalink) Old 08-26-2019, 09:25 AM
Motorbikerx's Avatar
Thanks HC just got my answer
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
Motorbikerx is offline
post #9 of 16 (permalink) Old 08-26-2019, 04:09 PM
Send a message via Yahoo to destonof2
I did it on my kawasaki no problem
destonof2 is offline
post #10 of 16 (permalink) Old 08-26-2019, 04:49 PM
My XC gets squrrelly on bias-plys. I have a set of bias-plys on now with only 3,000 miles and ordered radials to replace them. (which I'll probably change over tomorrow).
Way back I replaced the OEM tires with Commander II's(bias) and the bike developed a wobble, especially in long turns. I switched to radial Avon Cobras and never experienced the problem again. Until....I bought the rear bias-ply tire I have on now by mistake, so I put a front bias-ply on to match it. Yep, the wobble returned.
swiftdescent likes this.
