Sudden engine shutdown - Victory Forums - Victory Motorcycle Forum
post #1 of 22 (permalink) Old 08-17-2011, 02:57 PM Thread Starter
Default Sudden engine shutdown
My new 11 XC has suddenly shut down twice now. Like you hit the Kill switch. Anyone else have this happen?
KountryBoy is offline
post #2 of 22 (permalink) Old 08-17-2011, 03:27 PM
bfp
bfp's Avatar
Hasn't happened to me, but I've read it happening to a few. Usually it's a bad, loose battery cable. Give it a look
2010 cross roads Custom
2015 Ness Magnum
2016 Magnum X1 Custom
2013 Vision Custom
bfp is offline
post #3 of 22 (permalink) Old 08-17-2011, 03:47 PM
NOEMTZ's Avatar
How much fuel in tank? Some have pick up tubes sucking in air during turns or braking.
www.noemtz.com
NOEMTZ is offline
post #4 of 22 (permalink) Old 08-17-2011, 03:47 PM
toejam's Avatar
It's happened to me a few times - checked and tightened terminals, still did it afterwards. Had half a tank of fuel - just like hitting the kill switch.
2013 Anti-Freeze Green XC
Vance & Hines Slip On's
BadBoy Horn, PCV
Gustafsson +4 Windscreen
Picasso Nano PN2.350D Amp
HMD520 Gorilla Bagger Bars
2010 XC 116 Big Bore - Gone
2006 Hammer - Gone
toejam is offline
post #5 of 22 (permalink) Old 08-17-2011, 03:50 PM
Go to hardware store and buy two of these star washers one for each terminal. 1/4" size. There in the little bins.
post #6 of 22 (permalink) Old 08-17-2011, 06:31 PM
Tenac's Avatar
This has happen to me. Ended up being the 40 amp thermal breaker going bad. Check that also does it restart shortly after it dies???? And does it die often or just after awhile of riding?
2008 Hammer
LED
2 into 1 No baffle
Lloydz intake
Power Commander 3
CHROME
Speakers
Tenac is offline
post #7 of 22 (permalink) Old 08-18-2011, 01:09 AM
toejam's Avatar
Sure would like to see what Kevinx has to say about this.....
BadBoy Horn, PCV
2006 Hammer - Gone
toejam is offline
post #8 of 22 (permalink) Old 08-20-2011, 10:20 PM Thread Starter
Default Problem Solved
Thanks for the help. I took the bike in for its 500 mi. service and they found 2 events in the computer that indicated a fuel starvation problem. The first suggestion in their manual: check the battery cables. One was loose. Problem solved.
post #9 of 22 (permalink) Old 09-18-2011, 10:27 AM Thread Starter
Default Problem NOT solved
All worked fine for a couple of hundred miles after having the battery cable tightened, then 3 more failures. Checked the battery myself and it had good, tight connections, with no corrosion. Going back to dealer. Unfortunately, this is not something I can reproduce. Also, plenty of gas in the tank. This can happen with cold engine or warmed up engine.
post #10 of 22 (permalink) Old 09-29-2011, 05:57 AM
philmonger's Avatar
Do you lose you lights when it happens? If not, then it is not likely a battery issue. Maybe take a look at the coils and ignition switch. look for loose connections or cracks in the coil bodies.
philmonger is offline
