Electrical Problem, need help with diagnosis - Victory Forums - Victory Motorcycle Forum
post #1 of 6 (permalink) Old 08-17-2011, 07:13 PM Thread Starter
Default Electrical Problem, need help with diagnosis
I don't know much about electronics, so please forgive my ignorance.
Vegal Low, 2008 model, 3650 miles on it. Turned the key to the On position, lights went on, fuel pump primed, pressed the start button, it made a noise like an electrical component failed or shorted out.
Now, turn the key to the On position and nothing happens, no lights, no fuel pump priming, nothing.
Checked fuses in the fuse box, all are good. Checked the fuse on the battery cable, it's ok. Battery is charged.
Could it be a relay problem? How do I test a relay?
Any help is much appreciated.
Mark
MinnesotaVegasLow is offline
post #2 of 6 (permalink) Old 08-17-2011, 08:12 PM
NOEMTZ's Avatar
Remove and clean battery connections. reattach and try again. Also possible bad cell or two in battery.
www.noemtz.com
NOEMTZ is offline
post #3 of 6 (permalink) Old 08-17-2011, 09:31 PM
kevinx's Avatar
that is where I would start
kevinx is offline
post #4 of 6 (permalink) Old 08-18-2011, 12:29 AM
Tenac's Avatar
If nothing comes one at all start with battery then go straight to the 40 amp breaker thats the only thing between battery and fuse box.
2008 Hammer
LED
2 into 1 No baffle
Lloydz intake
Power Commander 3
CHROME
Speakers
Tenac is offline
post #5 of 6 (permalink) Old 08-18-2011, 04:48 AM Thread Starter
Default thanks
Thanks for all the help, I'll give these things a try right after work today.
post #6 of 6 (permalink) Old 08-18-2011, 05:00 PM Thread Starter
Default Problem solved
Loose battery cable was the issue.
Thanks much for all the help, saved me from a big headache.
Mark
