2011 XC Cruise Control Issues - Victory Forums - Victory Motorcycle Forum
post #1 of 15 (permalink) Old 08-17-2011, 08:33 PM Thread Starter
Default 2011 XC Cruise Control Issues
So I've had my 2011 XC for almost a month now. Been caught in about three rain showers / storms ("sunny" south Florida ) and either during or after, the cruise control stops working. Usually it will start working again a day or two later, or go between working and not working as it deems fit. I'm going to guess (hooray for Capt. Obvious!) that moisture is getting to a connection somewhere. I don't have a service manual and the closest Victory dealer is 4+ hours away, if this is even covered under warranty. I've tried searching for info on how to fix it but didn't find anything. Anyone else had this type of issue, and if so, or if you know how to fix it, what did you do?
Going on a Iron Butt ride Labor Day time frame so I'm really hoping to have it working flawlessly by then. I'll need it!
Lance
2011 Cross Country (White/Silver)
2006 CBR 600 RR (sold)
2001 Shadow A.C.E. 750 (sold)
Levocmk1 is offline
post #2 of 15 (permalink) Old 08-17-2011, 08:41 PM
wesdalton's Avatar
dielectric lube on all wiring plugs works for me. If Vic has a problem area (in my opinion), it is in their wiring. If you look at the lower crankcase by the rear brake actuator, there are many exposed wiring harness connectors that are just open to any moisture and corrosion. They could have taken a lesson from Suzuki. The wiring on my C-50 is considerably better with placement and keeping the connections out of the weather.
2010 X C
wesdalton is offline
post #3 of 15 (permalink) Old 08-17-2011, 09:02 PM
Does the cruise quit during operation (cruise drops out while in "cruise" mode), or is it that it won't come back on when you go to use it the next time?
Phideaux
2011 XC
2005 VTX 1800R Spec II
Phideaux is offline
post #4 of 15 (permalink) Old 08-17-2011, 09:04 PM
kevinx's Avatar
Tell your dealer to start an "Ask Polaris" case on it. Use the description you just typed. They will then autho a new style interface module for the cruise. That will not only solve your issue, but it will establish another case towards an open service bulletin
kevinx is offline
post #5 of 15 (permalink) Old 08-19-2011, 03:28 PM Thread Starter
It won't come back on next time I try to use it. The little green cruise control symbol flashes on and then back off again when I use the power on/off button. It won't come on at all when I hit Set.
Originally Posted by handyhoward
If you want to fix it properly you have to do it yourself or have someone who is qualified (the dealers are typically not trained nor qualified) do it. It involves removing the entire external system hidden behind the "cheese" wedge on the right side of the bike and weather proofing it... the whole enchilada... wires... hoses... connections. When this is done properly the system works better but still is not what one can refer to as top notch.
Guess I'll have to get some dielectric grease and go to town on all the connections I can find behind the cheese wedge.
Originally Posted by kevinx
Tell your dealer to start an "Ask Polaris" case on it. Use the description you just typed. They will then autho a new style interface module for the cruise. That will not only solve your issue, but it will establish another case towards an open service bulletin.
Dealer I got the bike from is actually about 6-7 hours away. If the dielectric grease on the connections doesn't work I guess I'll have to go this route.
Thanks for the help all.
Lance
Levocmk1 is offline
post #6 of 15 (permalink) Old 08-19-2011, 06:26 PM Thread Starter
Thanks for the tip HH. I'll be doing that this weekend along with a few other little projects on the bike.
Lance
Levocmk1 is offline
post #7 of 15 (permalink) Old 08-19-2011, 08:17 PM
had the same problem after going thru the worst rain storm I've ever been in. Next day the cruise wouldn't work. There is a two wire connection on the right side of the gas tank near the front. It connects at a 90 degree angle onto a cable. I think it might be the throttle cable. I pulled these wires off, blew them out and it worked fine. Need to fill the connections with the dielectric grease or seal them somehow.
2011 Cross roads
2009 Star 950 Tourer (sold)
2007 Suzuki Vstrom 650 (sold)
2032Ceta is offline
post #8 of 15 (permalink) Old 08-19-2011, 10:24 PM
kevinx's Avatar
Originally Posted by handyhoward View Post
Sure... let's do Polaris's work for them. The system sucks in it's basic design, but it can be fixed. Neither the dealer network nor Polaris will fix it properly because they are directed by the fact that this is "NORMAL" for this to happen.
Your kidding me right?? Instead of fixing the thing correctly. With a part made to work with the varied resistance caused by moisture in the magnetic cut switch. You would rather do a half ass repair, and then have to do the same thing every year or so??? Do you really consider glopping a bunch of RTV into electrical systems proper??
You have no idea of the level of technical competence at the OP's local dealer, and your advise in this matter is not only bad. It is irresponsible
This is not a matter of doing "Polaris's job for them". Rather it is a matter of putting an engineered fix in. When this is done the whole system works without a hitch.
kevinx is offline
post #9 of 15 (permalink) Old 08-20-2011, 12:09 AM Thread Starter
So if I get a dealer to open an "Ask Polaris" case they will get me a different control interface for the cruise control? I'm guessing this is a known issue then by Polaris and the different module is the fix?
Lance
Levocmk1 is offline
post #10 of 15 (permalink) Old 08-20-2011, 06:47 AM
kevinx's Avatar
That is correct. Done a couple of them at my store, and it i a 100% fix
kevinx is offline
