Pipes without a fuel controller? - Victory Forums - Victory Motorcycle Forum
post #1 of 5 (permalink) Old 08-23-2011, 01:33 PM Thread Starter
Rajder's Avatar
Default Pipes without a fuel controller?
Ok, I have a question for the guys who regularly tune the Victory's (KevinX, etc). I'm going to add RPW mufflers, Hi-performance air filter, remove the rubber strip on the air box, and eventually get a PC-5 and have it dyno tuned onto my 2011 XC.
I am wondering if I can install the RPW's now without having the air filter and PC-5 done yet? I have read that the factory fuel injection programming on these Victory's runs very lean and I don't want to get into a situation where the bike is running too lean.
If I just install the RPW's will the bike be fine if I leave everything else completely stock? What if I install the mufflers and pull the rubber strip on the intake while leaving the factory air filter? Will that be too much for the factory fuel map? Do I need to unplug the O2 sensors to get the bike to run richer? Or do I just need to wait and do everything at the same time?
I just really want to get some more sound out of the bike ASAP and if I can get some mild performance gains prior to the PC-5 then that would be great as well. But I don't want to make the bike run too lean either. Thanks.
2011 Cross Country
-Cee Baileys Windshield & Lowers. Victory Lower Bag Rails, Driver And Passenger Backrests.
-RPW Exhaust, Lloydz Air Filter, VM1 Cams, ATS (Timing Wheel), 1/4 turn throttle & IAV. PCV with Custom Tune by Coweta Customs.
105.2 HP & 127 Ft-Lbs on a Dynostar (Eddy Current) Dyno.
Rajder is offline
post #2 of 5 (permalink) Old 08-24-2011, 04:43 PM Thread Starter
Rajder's Avatar
Anyone has some insight on this? I'm pretty sure I can unplug the O2 sensors and run the RPW exhaust without a problem. But can I pull the rubber strip off of the airbox without having to reprogram the computer?
2011 Cross Country
Rajder is offline
post #3 of 5 (permalink) Old 08-24-2011, 07:02 PM
Vicbuilder's Avatar
You should be fine if you're just going to drive down to the shop to get the map, but if you are doing pipes and airbox mods you will need some kind of fuel controller or download.
Rylan Vos
The Vic Shop, Inc
(515)-339-4313
Vicbuilder is offline
post #4 of 5 (permalink) Old 08-24-2011, 07:21 PM
ashmostro's Avatar
I'm not an expert on these engines, but you should be okay if you aren't wringing it and it's not too hot where you are.
I would unplug the stock narrowband O2's as a precaution.
2011 Victory Kingpin 8-Ball
Tach / Dual front discs with Vesrah JL pads / Penske shock / S&S Intake / PCV & autotune / RPW Thor exhaust with homemade custom baffle / Tsukayu leather "Strong" bags / Avon Cobra *Radials* / Ness Vegas Peg Conversion / Ness Vegas driver's seat / Custom T-Apes from BR Custom Cycles
ashmostro is offline
post #5 of 5 (permalink) Old 08-24-2011, 09:19 PM Thread Starter
Rajder's Avatar
Yeah, I wasn't going to put the air filter in the bike until I could get the PC5 or the download done. My main concern was that I wanted to make sure I could run the RPW exhaust with the O2's unplugged and the stock tune for awhile while I'm waiting on the funds to do the PC5 and dynotune. That way I could at least have some extra sound from my exhaust while waiting on the PC5 and dynotune. I just wanted to make sure that the bike wasn't going to run too lean while I was running with just the exhaust.
2011 Cross Country
Rajder is offline
