Gas Pouring out of motor - Victory Forums - Victory Motorcycle Forum
post #1 of 36 (permalink) Old 03-06-2014, 02:26 PM Thread Starter
Default Gas Pouring out of motor
Hello all. After installing all of my updated from the past few weeks I went and tried to start up my bike. After realizing that I had the spark plug wires backwards (Insert comment here) the bike fired up. I realized that I had gas dripping down my exhaust so I shut the bike off.
Every time a primed the fuel pump about 10 seconds later gas would start running down the front exhaust. It doesn't look like its coming from where the exhaust enter the motor. The gasket halfway down from the tip seems to be where the leak is coming from.
It also is important to mention that I am 95% sure that I flooded the motor trying to get it to start when I had the spark plugs backwards.
Any ideas? I have no clue how this is possible.
2009 Vegas Low
S&S Intake, D&D Exhaust, Power Commander 5 w/ AutoTune, Full LED lighting, HID kit.
hockeyzebra27 is offline
post #2 of 36 (permalink) Old 03-06-2014, 02:43 PM
depot picker's Avatar
If you had the tank off, it is the connector from the tank. It is a biatch to get on right.
depot picker is offline
post #3 of 36 (permalink) Old 03-06-2014, 02:45 PM
CrossRoads's Avatar
Or the nipple's broken.
CrossRoads is offline
post #4 of 36 (permalink) Old 03-06-2014, 02:45 PM Thread Starter
I never disconnected it from the tank. I only disconnected the connector under the right cheese wedge.
2009 Vegas Low
post #5 of 36 (permalink) Old 03-06-2014, 02:49 PM
CrossRoads's Avatar
But did you break the nipple while moving the tank?
post #6 of 36 (permalink) Old 03-06-2014, 03:01 PM Thread Starter
I just went out and checked. Nipple is still in perfect working order.
2009 Vegas Low
post #7 of 36 (permalink) Old 03-06-2014, 03:11 PM
CrossRoads's Avatar
Try to dry it out, and maybe put paper towels around, and give it another squirt. See if you can find where it's coming from.
post #8 of 36 (permalink) Old 03-06-2014, 03:18 PM Thread Starter
I have it narrowed down to either where the exhaust goes into the motor or were the top and bottom section of the motor meet together. looks like there is a gasket. (The whole area is wet around the gasket)
2009 Vegas Low
post #9 of 36 (permalink) Old 03-06-2014, 03:20 PM
LILMAGS500's Avatar
HZ , make sure where the hose connects to the fuel rail it is properly snapped in , maybe even disconnect it and plug it back in , you should hear a pronounced "CLICK" when it snaps back in ....
LILMAGS500 is offline
post #10 of 36 (permalink) Old 03-06-2014, 03:23 PM
LILMAGS500's Avatar
It cant be coming out of the exhaust at the motor , you would have a massive exhaust leak , and some serious internal engine malfunctions .... Re- check hose connection .
