motor quitting - Victory Forums - Victory Motorcycle Forum
post #1 of 4 (permalink) Old 08-26-2011, 10:38 AM Thread Starter
Default motor quitting
I have a 2011 crosroads every so often especially after some highway running ,When I gert off the ramp the bike will just shut off,,It will start right back up no problem and run fine,,,Has anyone else had this issue?and what WAS done to fix it? thanks
frank4656 is offline
post #2 of 4 (permalink) Old 08-26-2011, 01:41 PM
leighhannah's Avatar
I've had that happen a couple of times since I bought my bike in April. I assumed that it was a side effect of my intake/exhaust setup. I have not had it looked at yet but assume it has something to do with the bike running lean.
2008 Vision Street
Custom paint; tinted turn signals; Lloydz cams, timing gear, PCIII; Hot Vic 26" Windmill wheel, billet wedges, tips, pegs & covers; Focal IC-130 5.25" speakers, Arc Audio KS 125.2 BX2 AMP; Hot Tails custom seat...
2012 High Ball
Custom exhaust; high performance air filter; Hot Vic sissy bar, lowered 1.5" rear, .5" front; Witchdoctor 2" peg extensions & pegs, Hot Tails custom seat & passenger pad...
leighhannah is offline
post #3 of 4 (permalink) Old 08-26-2011, 02:11 PM
PhilC64's Avatar
If the bike is still under warranty get it looked at by the dealer. This sounds unusual.
2015 XCT - Flying lounge chair
PCV, ATS +4, Lloydz filter, VM1-HPT cams, and Freedom True Duals.
2004 King Pin - 100 cid Big Bore, Ness Intake, Victory Performance Exhaust
2010 XR - Road toy
PCV, ATS +4, Lloydz filter, VM1-DR cams, and Freedom True Duals - traded
Cam Swap write up for X Series bikes:
https://docs.google.com/open?id=0B95...YW1XVXFpeU9fUQ
PhilC64 is offline
post #4 of 4 (permalink) Old 08-26-2011, 03:04 PM
There is whats called a Idle Air Valve or IAV it is suppose to keep your bike idling. You could have a vacuum line not all the way on.
See dealer and give him all the information you can on how it dies on you.
Most people don't give all or good information so it makes it hard for a dealer to fix and your only screwing your self by holding back.
