Cleaning Lloyds filter - Victory Forums - Victory Motorcycle Forum
post #1 of 33 (permalink) Old 03-11-2014, 06:36 PM Thread Starter
slickvic's Avatar
Default Cleaning Lloyds filter
Hey Fellas, a question about cleaning Lloyds filter. I used K&N cleaning solution and man it really cleaned the filter good. It was filthy!
My question is: Can I use the K&N filter oil ? Is this what we use? I have searched and found no cleaning instruction for these filters.
Thanks Gents.
slickvic is offline
post #2 of 33 (permalink) Old 03-11-2014, 07:31 PM
toejam's Avatar
Short answer - pretty sure that's whats recommended (its what I use)
2013 Anti-Freeze Green XC
Vance & Hines Slip On's
BadBoy Horn, PCV
Gustafsson +4 Windscreen
Picasso Nano PN2.350D Amp
HMD520 Gorilla Bagger Bars
2010 XC 116 Big Bore - Gone
2006 Hammer - Gone
toejam is offline
post #3 of 33 (permalink) Old 03-11-2014, 09:08 PM Thread Starter
slickvic's Avatar
Thanks TJ. I cant remember if the filter came oiled or not. Looking at the pics of Lloyds filter on his site It's blue in color. mine is pretty white now after cleaning. I would assume the blue is the oil.
slickvic is offline
post #4 of 33 (permalink) Old 03-11-2014, 09:57 PM
I've been wondering the same thing. I'm sure k and n oil will work fine. It will make it red. I'm sure someone sell blue filter oil.
99 Kawasaki Vulcan 800 (sold)
2012 Vegas (traded)
2013 Cross Country Tour
Victory Tri-Ovals, Reverse Kit, Lloydz air filter, Lloydz quarter turn throttle ring, PCV, Lloydz Touring cams, HMD Bars, DGD keyless ignition, Rockford Fosgate Amp, klockworks windshield. 119hp 123lbs torque.
jchris56 is offline
post #5 of 33 (permalink) Old 03-11-2014, 10:02 PM
Motorbikerx's Avatar
Smile
Thanks Gents.
Yeah the K&N recharge KIT is the one Id use,
Once youve washed it out with cleaner and water dont blow dry it with air. Just a shake and leave it in the sun (if you have such luxuries as sun, dont leave in the snow)..re oil let penetrate for 20 mins should be red all over.
Out of interest how many miles you clock up before you needed to clean and was there dirt roads?
My Ness filter will be a pain in the arse to remove for cleaning but hopefully by then I'll have the spare $ fot torque tubes
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
Motorbikerx is offline
post #6 of 33 (permalink) Old 03-11-2014, 10:32 PM Thread Starter
slickvic's Avatar
It's in over a year and about 7k for miles. There were a few dirt roads and events that were dirt and dust fields. It may be to early to clean it now but how do you know unless you check it. Removing the seat then the tanks a PITA so I might as well go a head and clean it. A lot of dirt washed out. I use K&N on all my vehicles so I have a re charge kit. I just didn't know if Lloyd had something else in mind.
slickvic is offline
post #7 of 33 (permalink) Old 03-11-2014, 11:34 PM
just the seat and tank ...youre fortunate.. with the Ness unit the four bolt that secure it to the throttle bodies have to be undone too...now that IS a P.I.T.A. ,price I paid for a cheaper filter, and couldnt see the point in bling you can't see...
now if LLOYDZ made a plain topped one along the same lines at a competetive price to the Ness that would make sense!
I try to stay off dirt roads even though theyre great on the dirt!
Victory Vegas 2010
" " 495 cams
" " TorqueTubes
" " Primary plate
" " IAV
RPW Slash pipes
Kingpin USD Forks
18" XC front wheel
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
post #8 of 33 (permalink) Old 03-12-2014, 09:08 AM
I found blue filter service kits on summit racing. They are for AFE brand filters.
http://www.summitracing.com/search/P...il-Color/Blue/
2012 Vegas (traded)
jchris56 is offline
post #9 of 33 (permalink) Old 03-12-2014, 12:10 PM
I asked KMC if the Lloydz filter was rechargeble (like K&N cleaning it) and he said no, you must buy new. This is on my CCT last year. Please correct me if I am wrong.
DaveReed is offline
post #10 of 33 (permalink) Old 03-12-2014, 12:15 PM
depot picker's Avatar
It is a permanent filter.
depot picker is offline
