Power for Gerbing - Victory Forums - Victory Motorcycle Forum
post #1 of 9 (permalink) Old 08-28-2011, 12:12 PM Thread Starter
Default Power for Gerbing
Just getting ready to mount my power cord for my Gerbing heated gear to my 2011 Crossroads. Of course the simple battery under the seat run a short wire and youre done trick won't work on this one because the battery is mounted up front.
Has anyone come up with any creative ideas for running wires for heated gear? Minimal wire length would be nice.
Billy
2014 XC
2006 Vegas 8 Ball
2014 Harley FLHTP (Keeping service techs busy)
Billyrides is offline
post #2 of 9 (permalink) Old 09-06-2011, 04:29 AM
Bumping this topic back up. I'm fixing to do the same thing myself; winter is coming. Any suggestions?
willtill is offline
post #3 of 9 (permalink) Old 09-06-2011, 06:40 AM
MTVic's Avatar
I plan to tap mine into the trunk pack accessory plug which runs under or next to the seat (CC Tour) once I figure out which wires in the bundle are them! Speakers run back there too.
Anyone out there have a schematic or can tell me which color wires?
Mike
FORMERLY 2012 Black XC Tour
2016 Honda NM4
2014 Honda CTX 700 dct
MTVic is offline
post #4 of 9 (permalink) Old 09-06-2011, 09:52 AM
ammo_umb's Avatar
There is power under the right side panel and another connection on the rear exhaust/bag support crossmember (near the rear or the fender). Either of these should work; the one under the side panel is for the heated seat and (I think) the one on the cross member is for the powerlet connection in the right saddlebag.
Retired USAF, IYAAYAS!
ammo_umb is offline
post #5 of 9 (permalink) Old 09-06-2011, 10:49 AM
MTVic's Avatar
I don't want to tie into the heated seat, amy be too high amps all 3 running! The power to the rear trunk I think is 15 amps.
Mike
2016 Honda NM4
MTVic is offline
post #6 of 9 (permalink) Old 09-06-2011, 11:06 AM
If you go to Gerbing web site you can find adapter that will plug into the battery tend plug so you don't need extra wires
post #7 of 9 (permalink) Old 09-06-2011, 11:31 AM
Powerlet makes an outlet that mounts to the backside of the primary at the clutch cable bracket and wires will reach battery.
Geo.
gwritesel is offline
post #8 of 9 (permalink) Old 09-06-2011, 12:57 PM
MTVic's Avatar
Careful on that route. My pigtail only carries a 5amp fuse, Gerber and most heat controllers want a minimum of 10 amp.
Mike
2016 Honda NM4
MTVic is offline
post #9 of 9 (permalink) Old 12-08-2011, 03:57 PM
I just used the power cord that came with my Gerbing heated jacket liner and hooked it to the battery as per instructions. Then ran the fused power cord from the battery up along the left side of the bike (same route as the wires already there). Then once above the cylinder I ran it back towards the seat behind the cheese wedge and that where you run out of cord, just in front of the seat on the left side. Perfect.
2011 Victory XR (Cross Roads)
09 Suzuki 650 V-strom
2005 Suzuki SV-650 (sold)
2001 TTR-125 Yamaha
1991 Honda NT650 Hawk (crashed,repaired,sold)
1982 GPZ 550 Kawasaki (sold)
1980 GS 750E Suzuki (crashed,repaired,sold)
1972 Schwinn Paperboy (stolen)
Tricycle 1960
Born 1957
T-man is offline
