Possible Fuel Issue(s) - Victory Forums - Victory Motorcycle Forum
post #1 of 8 (permalink) Old 03-13-2014, 11:17 AM Thread Starter
4wilds's Avatar
Default Possible Fuel Issue(s)
I have a 2014 Cross Country 8-Ball that I picked up in January. Since the weather has been weird around here I haven't had many chances to ride. I just 500 miles and have filled up the tank 3 times so far.
Well this Monday I stopped and filled up, put in 4.21 gallons and could see the gas in the tank just below the neck so I know it was full. I've been watching my trip odometer and MPG estimator just for giggles. According to the estimator I am getting between 47 and 53mpg, and my odometer is reading 107 miles since last fill up. My fuel gauge is showing just above empty, so I'm a little confused.
The other thing I have noticed since Monday is that once I get home and park her in the garage there is a STRONG gas smell. If I go back out into the garage an hour later the garage smells like I left a gas can open somewhere. I don't see any leaks on the floor of the garage so there doesn't seem to be a leak or at least not a big enough one to leave a trail.
Any ideas?
VictoryHID Hi/Lo 6k
2003 SV650N
Yoshi Full Exhaust
K&N Air Filter
Power Commander III
ZX14 Rear Shock
R6 Throttle Tube Mod
Rear Seat Delete
D&M HID Conversion
Will be undergoing track bike conversion soon
4wilds is offline
post #2 of 8 (permalink) Old 03-13-2014, 12:35 PM
Do not believe your gage its giving you a easement of what your mileage is. Use your phone. Vic gages are not the best for telling you miles per gallon.
Check your gas cap to see if its sealing tight. You should see by looking at your rubber gasket a shinny seal mark all the way around. Look at the lip on the tank is it bent it should be flat all the way around.
post #3 of 8 (permalink) Old 03-13-2014, 10:27 PM
KNielsen's Avatar
before tearing into anything, top off your tank to the brim some evening and check it in the AM, if its down, you know you have a problem with the bike. if its not, well then idk
07 Kingpin
Bob Dron Fairing
Dakota Digital Tach
L.E.D. Tail Light
H.I.D.s
Stage 1 Shotgun Pipes
1/4 Turn Throttle
KNielsen is offline
post #4 of 8 (permalink) Old 03-14-2014, 01:30 AM Thread Starter
4wilds's Avatar
Well I got home this evening, at 148 miles the fuel light came on and the Low Fuel Idiot Light is on. My garage smells like gas but again no puddles.
VJ, I looked at the inside lip and its flat as you stated, the cap seales well and is flush with the cap ring.
I'm going to fill up in the morning and then take the car to work that way I can verify the fuel level once I get home tomorrow.
We'll see what happens.
VictoryHID Hi/Lo 6k
2003 SV650N
Yoshi Full Exhaust
K&N Air Filter
Power Commander III
ZX14 Rear Shock
Rear Seat Delete
D&M HID Conversion
4wilds is offline
post #5 of 8 (permalink) Old 03-14-2014, 06:01 AM
TNXR's Avatar
Your bike is under warranty so take it to the dealer and let them look at it. If your dealer is not that good at working on Vics then take it to another dealer.
2011 Cross Roads Sunset Red
TNXR is offline
post #6 of 8 (permalink) Old 03-14-2014, 11:57 AM Thread Starter
4wilds's Avatar
Its do for its first oil change under break-in and was planning on taking it up there tomorrow. While its there I will discuss it with them.
Thanks
VictoryHID Hi/Lo 6k
2003 SV650N
Yoshi Full Exhaust
K&N Air Filter
Power Commander III
ZX14 Rear Shock
Rear Seat Delete
D&M HID Conversion
4wilds is offline
post #7 of 8 (permalink) Old 03-14-2014, 06:56 PM
Luciferiad's Avatar
The fuel gauge on my XR is a filthy liar. When I do the math, I average between 42-45 mpg, but I hit "empty" and my light comes on with 2 gallons still in the tank, a little more sometimes. I use it more to gauge when I need to start checking my trip meter than any accurate indicator of how much fuel I have left.
Mine:
2011 Cross Roads, crimson red
Hers
2015 Vegas 8-Ball
Luciferiad is offline
post #8 of 8 (permalink) Old 10-28-2014, 12:48 AM
newj64's Avatar
Hey 4Wild,
Any updates on the fuel issue?
14' Cross Country
~PCV, Timing Wheel +6, Thrush Mod Exhaust, Madstad 11" windshield
newj64 is offline
