Needing some opinions for setting fuel map on PCV - Victory Forums - Victory Motorcycle Forum
post #1 of 12 (permalink) Old 03-13-2014, 08:43 PM Thread Starter
XzombieX66's Avatar
Default Needing some opinions for setting fuel map on PCV
So i got the PCV and it has fuel motos map preloaded with some minor adjustments, i feel like the engine is running rich. looking for some opinions on the values these should be set at. i feel like some are set to high in the lower rpm and throttle ranges. My mods are in my sig.
Big Gonzo Mufflers
Lloydz adjustable timing wheel
Ness RAD III Mirrors, Ness Deep cut grips
Vic Hids, Vic Baggers Tarzanz Bars +1 rise +2 pull
Vic Baggers 6.5 degree triple trees
Gorby's Machine 23 inch wheel- Windmill contrast cut,
23 inch wrap around front fender, Whitewall choppers Radio control Bezel and 1.5in Lowering link...
XzombieX66 is offline
post #2 of 12 (permalink) Old 03-13-2014, 09:12 PM
MTVic's Avatar
Those are pretty high settings at zero throttle. Normally 0 to 5. Are you getting any back fire or farting?
Mike
FORMERLY 2012 Black XC Tour
2016 Honda NM4
2014 Honda CTX 700 dct
MTVic is offline
post #3 of 12 (permalink) Old 03-13-2014, 10:19 PM Thread Starter
XzombieX66's Avatar
Yeah it does sometimes
Big Gonzo Mufflers
post #4 of 12 (permalink) Old 03-13-2014, 10:20 PM
KNielsen's Avatar
I dont have anything to contribute but before buying a fuel controller its nice to see what the setup looks like, thanks for the screenshot
07 Kingpin
Bob Dron Fairing
Dakota Digital Tach
L.E.D. Tail Light
H.I.D.s
Stage 1 Shotgun Pipes
1/4 Turn Throttle
KNielsen is offline
post #5 of 12 (permalink) Old 03-14-2014, 03:32 AM
half_crazy's Avatar
Find a good dyno tuner and your problems will all be solved. There are 250 cells on that table... every 250 rpm and 9 throttle positions... separate table for each cylinder... Believe me, you can't seat-of-the-pants tune that.
2006 Victory Kingpin
half_crazy is offline
post #6 of 12 (permalink) Old 03-14-2014, 04:47 AM
Motorbikerx's Avatar
Originally Posted by half_crazy View Post
Find a good dyno tuner and you problems will all be solved. There are 250 cells on that table... every 250 rpm and 9 throttle positions... separate table for each cylinder... Believe me, you can't seat-of-the-pants tune that.
correct...I watched Steve at Powerhouse go thru every step of the tune thru a window in the dyno booth...VERY comprehensive.
then when he had it close he ran it up to the limiter, made some more fine adjustments, ran it up again. a few more adjustments, then on the third run he was happy...still wanted me to ride it before paying him, and told me to bring it back if it needs a bit more put in or taken out anywhere...
worth every cent
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
Motorbikerx is offline
post #7 of 12 (permalink) Old 03-14-2014, 09:20 AM Thread Starter
XzombieX66's Avatar
i planned on having it dynoed but was going to wait until the Rally in Georgia and have it done down there. I found a local guy and he wants 250.00 to dyno tune it. seems like alot but im not sure?
Big Gonzo Mufflers
post #8 of 12 (permalink) Old 03-14-2014, 09:28 AM
vindex1963's Avatar
The 10s and 15s at 0 throttle posisition help with decel pop and what half_crazy said find a tuner.
1/4 turn throttle ring
Tank riser
VM-1 DR cams
Timing wheel +4
Lloydz high-flow air cleaner
Bassani baffled OEM mufflers
PC-V 118hp 116tq
vindex1963 is online now
post #9 of 12 (permalink) Old 03-14-2014, 11:05 AM Thread Starter
XzombieX66's Avatar
im just going to buy the Auto Tune.seems like the better money than spending it on a dyno.
Big Gonzo Mufflers
post #10 of 12 (permalink) Old 03-14-2014, 01:14 PM
dtmmil's Avatar
I have the at, you still need to get it set right, $250 for the dyno isnt bad. With the at you still need to set the proper af ratios, it doesnt do it for you.
Sent from Motorcycle.com App
currently bikeless
2012 Cross Country(Imp blue)
Hawley MN(sold)
dtmmil is offline
