Cross bike intake tweaking? - Victory Forums - Victory Motorcycle Forum
post #1 of 30 (permalink) Old 03-14-2014, 01:21 PM Thread Starter
dtmmil's Avatar
Default Cross bike intake tweaking?
Since the cross bikes intake is in the frame, under the tank and sucks air from under the tank, in front, and probably sucking hot engine heat from below, what would someone think about putting some weatherstripping of some type around the sides and back of the intake hole to block the hot underside air and make it suck from under the tank and forward where the fresh air can come in? Ive thought about trying this, not sure if it would do a lot of good or not.
Sent from Motorcycle.com App
currently bikeless
2012 Cross Country(Imp blue)
Hawley MN(sold)
dtmmil is offline
post #2 of 30 (permalink) Old 03-14-2014, 02:24 PM
Hey, where've ya been DT, missed ya. I think drawing in air hotter than ambient would only be occurring while stopped. Once under way, you're sucking in ambients.
RICZ is online now
post #3 of 30 (permalink) Old 03-14-2014, 05:02 PM Thread Starter
dtmmil's Avatar
Ive been around, popping in here and there, but with all the app troubles i have for the site i have been kinda avoiding the site from my phone, and since im never on a home computer, well im not here that often.
currently bikeless
Hawley MN(sold)
dtmmil is offline
post #4 of 30 (permalink) Old 03-14-2014, 06:06 PM
CrossRoads's Avatar
What if you could draw the intanke from an oxygen tank?
CrossRoads is offline
post #5 of 30 (permalink) Old 03-14-2014, 06:12 PM
slickvic's Avatar
I have my tank off now servicing the filter. Amazing how this frame provides adequate air.
slickvic is offline
post #6 of 30 (permalink) Old 03-14-2014, 06:13 PM
If you could get some tubes going from the front say under faring and channel it to the gap between the frame and the tank you might get a good air flow.
Even some kinda plate on top of the rocker box's that would not allow the air or heat to go upward.
post #7 of 30 (permalink) Old 03-14-2014, 06:30 PM
slickvic's Avatar
Old school hot rod thinking. Love it!
slickvic is offline
post #8 of 30 (permalink) Old 03-14-2014, 06:35 PM Thread Starter
dtmmil's Avatar
There are no holes in the frame to let air in, with the stock filter its forced to draw from the rear/underside of the tank, with the lloydz it has to draw from a larger area but still under the tank.
currently bikeless
Hawley MN(sold)
dtmmil is offline
post #9 of 30 (permalink) Old 03-15-2014, 06:47 AM
irv
irv's Avatar
oh boy! a ram air iv decal on my tank. i can see rics gears
turning on this one too. got a good point. colder denser air
makes more power, but you have to be moving at a good
speed to use it.
used to have a cold air setup fitted to a couple of vehicles
back in the 60's. 59 ford with a 390/375 and a 67 390 mustang.
ah the good old days!
mph faster].
irv is offline
post #10 of 30 (permalink) Old 03-15-2014, 07:02 AM
half_crazy's Avatar
http://vicbaggers.com/frame.html
2006 Victory Kingpin
half_crazy is offline
