Drill holes in the airbox? - Victory Forums - Victory Motorcycle Forum
post #1 of 18 (permalink) Old 09-04-2011, 06:13 PM Thread Starter
Default Drill holes in the airbox?
My Vegas has the Stage 1 kit. The airbox has intake mesh on the left cover (the part that you remove to get to the (K&N) filter cartridge.
Can I (and should I) drill holes on the right hand side of the airbox (obviously in the front section, before the air passes through the filter element)? Would there be any benefit, or even more important, any risk or detriment to doing this? Don't want to screw up the reliability as the bike's already running just fine...
Thoughts? Here's a pic of the airbox....
2003 Vegas, Billet Wheels , Drag Bars, Stage 1
vegaslad is offline
post #2 of 18 (permalink) Old 09-04-2011, 06:57 PM
CrossRoads's Avatar
Since drilling holes would allow a higher air volume to flow through, possibly getting your bike a tad too lean, one question persists in my mind: Do you have a fuel controller in place, or are you willing to add one once the holes are drilled?
Aside from that aspect, the holes can't be too bad of an idea. Make sure you drill holes at the bottom as well, in case any moisture gets it, so it can drip out at the bottom. Speaking of moisture, you'll have to be extra careful when you wash the bike if holes are drilled. Water will be your worst enemy.
Also, you might want to consider an aftermarket air intake all together (ie. S&S).
CrossRoads is offline
post #3 of 18 (permalink) Old 09-04-2011, 08:13 PM
kevinx's Avatar
Leave the right side of the box alone. Pull the horn and drill two 7/8 holes in the flat between the frame rails
kevinx is offline
post #4 of 18 (permalink) Old 09-05-2011, 04:48 AM
EDHARRISON's Avatar
Kevin - would this also benefit a 2009 100ci with stage 1?
thanks
Victory Vegas 8 Ball 2009 (5 speed 100ci)
Stage 1 with Swept black exhaust / Ness bars / Lowered
EDHARRISON is offline
post #5 of 18 (permalink) Old 09-05-2011, 06:12 AM
kevinx's Avatar
thanks
09 box already has large opening there
kevinx is offline
post #6 of 18 (permalink) Old 09-05-2011, 01:57 PM
EDHARRISON's Avatar
Thanks Kevin
post #7 of 18 (permalink) Old 09-05-2011, 06:15 PM Thread Starter
Thanks Crossroads; not sure if the conversion included a fuel controller - how can I tell?
Kevin, noted your comments about the 7/8th dia holes...thanks. Is there a reason for that specific diameter? Just wondering....
vegaslad is offline
post #8 of 18 (permalink) Old 09-05-2011, 08:23 PM
kevinx's Avatar
One real good reason. It fits!! As for mixture. You can get away without any changes.
kevinx is offline
post #9 of 18 (permalink) Old 09-10-2011, 07:01 PM Thread Starter
Default Airbox update!
So I went to drill the front of the airbox. Removed the horn, thought...."hmmm, I'll take off the side cover and check from the inside" (facing front of the bike)...and there's already a 2 inches square hole, right behind the horn! No need for more holes, me thinks.
So, I put away the drill, refitted the horn and away we go....maybe already an upgraded airbox?
vegaslad is offline
post #10 of 18 (permalink) Old 09-10-2011, 07:08 PM
New Member
I think they're all like that.
TrashmanNYC is offline
