Multi Function Display - Victory Forums - Victory Motorcycle Forum
post #1 of 3 (permalink) Old 09-04-2011, 07:49 PM Thread Starter
Default Multi Function Display
All of the Modes appear to be working except the fuel level -- it reads all over the map and mostly 0 gals which keeps the low fuel level light flashing all the time.
Also, the "Chk Engine" message flashes every 5 seconds. May only need resetting since the battery has gone dead a time or two.
I am inclined to pull the gas tank fuel gauge to see if there is anything I can fix short of replacing of the level element.
Any suggestions?
2000 V92C
Corpus Christi, TX
76 years and still DIY & Riding
Winged-V is offline
post #2 of 3 (permalink) Old 09-04-2011, 08:10 PM
kevinx's Avatar
Ground wire on the bottom of the tanks sending unit regularly breaks at the connector.
For the CEL try the throttle point setting stickied to the top of tech forum
kevinx is offline
post #3 of 3 (permalink) Old 09-04-2011, 08:38 PM Thread Starter
Will check out the sending unit wiring.
Tried the Throttle Point reset -- so far it hasn't cleared the CEL.
Thanks for all of the expertise from everyone.
2000 V92C
Corpus Christi, TX
Winged-V is offline
