Above 85 out and motor pings alot ! - Victory Forums - Victory Motorcycle Forum
post #1 of 25 (permalink) Old 09-06-2011, 06:13 PM Thread Starter
Default Above 85 out and motor pings alot !
Hello
I have a 2011 kingpin 106. I bought in April.
Just got back from 3000 mile trip.
When I am pulling a hill at 2500rpm and got to speed up.
The motor pins loud too. I have to down shift two gears
And get her up to 4600rpm to make better or just keep rolling out of the throttle.
She has a blow head gasket now dealer is fixing.
Always run 91 octain have sweep pipes and kn filter dealer installed.
I am in CA
Please help thanks Shawn
Thanks for the help Dealer said head gasket ok it was grease from exhaust. They said that they did nothing but bike does not ping or pop out exhaust like it used to. I think they forgot to flash it for pipes.
Thanks again all good
Shawn at JEFFco
Jeffco is offline
post #2 of 25 (permalink) Old 09-06-2011, 06:24 PM Thread Starter
Default 106 2011 motor pinging up every hill when it's hot out
It a 2011 kingpin swept pipes kn filter
I have to down shift 2 gears to get to 4600 rpm to help pinging..
Or get out of the throttle an just slow down.
Not a little pinging it's loud and bad. Got her in April has 10,000 miles now and a blow head gasket
Thank for any help Shawn at JEFFco
Jeffco is offline
post #3 of 25 (permalink) Old 09-06-2011, 11:52 PM
Was it running toooo leeeeeeeeeean possibly? Thus the pinging and blown headgasket. When an engine pings it is like an explosion inside the cylinder,things can come apart.
Speedblue is offline
post #4 of 25 (permalink) Old 09-07-2011, 01:30 AM
Bad V V's Avatar
I kind of don't get it. What do you want us to help you with? You have a blown head gasket and dealer is fixing it. My guess is your bike was running funny because it wasn't right to begin with so it blew the head gasket. I say let the dealer fix your bike take it for a ride and if it still is making funny pinging noises then we'll try to help you.
2003 Victory vegas
Bad V V is offline
post #5 of 25 (permalink) Old 09-07-2011, 07:55 AM
handyhoward's Avatar
Originally Posted by Jeffco View Post
Hello
I am in CA
Shut up and quit your bitching... Polaris/Victory don't make mistakes... you obviously have done something to make this bike not run properly. It's a fluke so we can't (spelled "won't") help you figure it out. LMAO
Handy
2013 Indian Vintage Chief FE... #7 of 25
2011 Victory Vision Tour Premium...
handyhoward is offline
post #6 of 25 (permalink) Old 09-07-2011, 08:35 AM
wesdalton's Avatar
You sound like a broken record, find a hobby other than wasting space on the forum
2010 X C
wesdalton is offline
post #7 of 25 (permalink) Old 09-07-2011, 10:18 AM
CrossRoads's Avatar
Guys, don't throw punches unless the target's already wearing a full face helmet. Safety first.
CrossRoads is offline
post #8 of 25 (permalink) Old 09-07-2011, 10:59 AM
Sounds like a bad tune. If it had been re-flashed, and I'm assuming you had the Stage 1 flash already done, then it probably would have avoided the down time. Gotta wonder what other damage has been done to the motor that won't show up right away as well.
Did you install the pipes and filter? Did you get the Stage 1 flash?
post #9 of 25 (permalink) Old 09-07-2011, 11:45 AM
Bad V V's Avatar
Sounds like it was the wrong octane gas made it all start.
2003 Victory vegas
Bad V V is offline
post #10 of 25 (permalink) Old 09-07-2011, 02:38 PM
kingpin6634's Avatar
Default Re: Octane
I get some mild pinging on my 06 KP. I run 91 octane because that is all I can find. I can't find 93 octane around anymore. Should we be using Octane booster if all we can find is 91?
I just installed the Stage 1 slip on kit and had the dealer remap the bike. Still get a little pinging.
I know in a car engine pinging is called pre-ignition and happens because of timing issues. I think it is caused by the timing being to advanced. Is it the same for our Victory KPs?
'06 Kingpin BIG RED
Has:
Custom Seat
Edge Bags with Ghost Brackets
Chrome Battery Cover
Chrome Starter Cover
Chrome Oil Cooler Cover (KINGPIN)
Chrome Driver Floor Boards
Victory Chrome Gear Box Insert
Lay Down License Plate Bracket
Kewlmetal 2" Pullback Risers
Stage 1 Exhaust Kit
Coming Soon:
After Market Turn Signals Front and Back
Money is no option, but without it my options are limited.
kingpin6634 is offline
