Valve chatter or something else??? - Victory Forums - Victory Motorcycle Forum
post #1 of 10 (permalink) Old 03-21-2014, 03:17 PM Thread Starter
XzombieX66's Avatar
Default Valve chatter or something else???
Ever since I put the Adjustable time system, torque tubes and IAC on, i have been getting what sounds like valve chatter between 2000-2500 rpms when accelerating. To me it sounds like the timing is off like on my older cars, but im not 100% I have the lloydz ATS set at 4 advanced. any ideas?
Big Gonzo Mufflers
Lloydz adjustable timing wheel
Ness RAD III Mirrors, Ness Deep cut grips
Vic Hids, Vic Baggers Tarzanz Bars +1 rise +2 pull
Vic Baggers 6.5 degree triple trees
Gorby's Machine 23 inch wheel- Windmill contrast cut,
23 inch wrap around front fender, Whitewall choppers Radio control Bezel and 1.5in Lowering link...
XzombieX66 is offline
post #2 of 10 (permalink) Old 03-21-2014, 03:25 PM
LILMAGS500's Avatar
Is it pinging ? Sounds like it is , what octane fuel are you running , I wouldn't run less then 93 with 4D advance ... If you have a PCV make sure your ignition tables are set to 0 . I realize this kicks in at 2500 RPM , but better to be safe then sorry . Also , is it under a load or at cruise ? Does it do it in neutral and simply bringing the RPM's up to 2500 ?
LILMAGS500 is offline
post #3 of 10 (permalink) Old 03-21-2014, 03:40 PM
slickvic's Avatar
Back your timing down to 3 and try it. You are detonating. Make sure you are running 93 octane. Go to 2* next if the problem still exists.
slickvic is offline
post #4 of 10 (permalink) Old 03-21-2014, 06:17 PM
with the torque tubes you will here more of the motor. So if your going into the wheel put at zero and after a hundred miles move it to +1 and so on.
post #5 of 10 (permalink) Old 03-22-2014, 08:45 AM Thread Starter
XzombieX66's Avatar
I run 93 octane, PCV is zeroed out, it only does it under load.
Big Gonzo Mufflers
post #6 of 10 (permalink) Old 03-22-2014, 10:06 AM
LILMAGS500's Avatar
You put it back to 0 ?
post #7 of 10 (permalink) Old 03-22-2014, 12:03 PM Thread Starter
XzombieX66's Avatar
I haven't tried that yet, i was going to dial back to 3 and see how it sounds.
Big Gonzo Mufflers
post #8 of 10 (permalink) Old 03-22-2014, 12:16 PM
LILMAGS500's Avatar
Ok , I gotcha ... I missed where you said the PCV . Let me know how you make out as I have mine to start @ +4 also . If mine pings or rattles I'm just going to drop 1 degree at a time until its quiet ...
post #9 of 10 (permalink) Old 03-22-2014, 12:18 PM Thread Starter
XzombieX66's Avatar
cool ill let you know.
Big Gonzo Mufflers
post #10 of 10 (permalink) Old 03-22-2014, 12:19 PM
LILMAGS500's Avatar
Thanks Zombie
