Fuel Leak - Victory Forums - Victory Motorcycle Forum
post #1 of 3 (permalink) Old 03-21-2014, 04:56 PM Thread Starter
Default Fuel Leak
Guys, any help would be appreciated. I have a couple problems, but the first is a slight fuel leak. I just finished installing my Thor pipes and PCV. I did end up taking the tank off, but when I went to prime the fuel pump, I noticed a small leak coming from the fuel line where it connects to the fuel rail. Is this normal till it's primed? I have a '13 Hammer 8 Ball.
The other question I had was about the PCV map. So far those are the only two performance mods I have. Can I get away with the stock map the PCV came with? I've read the M19-002-003.pvm map from dynojet may work ask well.
Any inputs would be appreciated, thanks!
Bone stock (for now) '13 Hammer 8-Ball
ThrowDownTheHammer is offline
post #2 of 3 (permalink) Old 03-21-2014, 06:11 PM
take line off put back on. If its quick connect you should here a click when it snaps in place.
Don't think the PCV will do much for you but write Rylan and the Vic shop he will send you a starting map
post #3 of 3 (permalink) Old 03-21-2014, 06:15 PM Thread Starter
Thanks Johnny, I do have the quick connectors...tried pulling the line off, then putting it back on, but I still have a small leak.
