belt guard inspection - Victory Forums - Victory Motorcycle Forum
post #1 of 33 (permalink) Old 03-21-2014, 06:39 PM Thread Starter
NJ8BALL's Avatar
Default belt guard inspection
Ive been noticing a noise not a chirp coming from the belt area. I removed the belt guard today to have a look and it appears the belt is slapping on the underside of the guard.
Is something I should be concerned about?
When I had the guard off the bike was on the side stand. I put pressure of the belt downwards and it basically met up with the swingarm. Seems kinda loose, but the belt was adjusted at Lloyds this past Oct
'09 Kingpin 8-Ball...Sanded chrome exhaust, Stage 1 slipons, VFCIII, Lloyds IAV, Stonny's 27" sissybar, Edge bags with ghost brackets,Kuryakyn black ISO grips,
http://www.bluebeardimagery.com/
http://blue-beard-imagery.artistwebsites.com/
Photo equip: Canon 60D, Canon 55-250is, Canon 18-55, Canon 70-200f4,Tamron SP10-24
NJ8BALL is offline
post #2 of 33 (permalink) Old 03-21-2014, 06:43 PM
4 inch pistons's Avatar
Has the bike been lowered? I just found out that lowering the bike---x bike anyway, will cause them to rub against a rib on the belt guard. It can be removed with no problems.
[SIGPIC]
[/SIGPIC]
"The Road Goes on Forever and the Party Never Ends"-Robert Earl Keen
4 inch pistons is offline
post #3 of 33 (permalink) Old 03-21-2014, 06:51 PM Thread Starter
NJ8BALL's Avatar
Never lowered
NJ8BALL is offline
post #4 of 33 (permalink) Old 03-21-2014, 07:39 PM
dtmmil's Avatar
It may be to loose, but as the belt warms up it tightens up.
Sent from Motorcycle.com App
currently bikeless
2012 Cross Country(Imp blue)
Hawley MN(sold)
dtmmil is offline
post #5 of 33 (permalink) Old 03-21-2014, 08:21 PM Thread Starter
NJ8BALL's Avatar
So, I forget to check the belt it's done cold correct
NJ8BALL is offline
post #6 of 33 (permalink) Old 03-21-2014, 08:25 PM
dtmmil's Avatar
Yes.
currently bikeless
Hawley MN(sold)
dtmmil is offline
post #7 of 33 (permalink) Old 03-21-2014, 10:18 PM
At the spot exactly between the front and rear pulleys, stand a tape measure extended to at least 2" above the lower span of the belt. Note the dimension on the tape. Press upward with some sort of scale and apply 10 pounds of pressure on the belt where the tape is. If the belt is adjusted properly, it will have raised 1-1/4".
post #8 of 33 (permalink) Old 03-22-2014, 06:38 AM Thread Starter
NJ8BALL's Avatar
Your doing this with the bike on the ground or on a lift?
NJ8BALL is offline
post #9 of 33 (permalink) Old 03-22-2014, 08:19 AM
dtmmil's Avatar
Pretty sure the manual says for the cross bikes to be in the air.
currently bikeless
Hawley MN(sold)
dtmmil is offline
post #10 of 33 (permalink) Old 03-22-2014, 08:22 AM
Ferta_McDaniels's Avatar
From the conversations I have had with Lloyd, he has mentioned to me more than once to keep the belt loose. He never said why exactly but the conversation was about me breaking my belt.
PFloyd (Ferta)
2014 Vision Nuclear Sunset
XM Radio Module
Sequential Turn Signals F/R
1/4 Turn Throttle Ring
HID Headlights & Cyclops
Vic Shop Tweaks: 124 HP / 121 Torque
04 Purple Thunder Kingpin (Sold)
Ferta_McDaniels is offline
