01 V92C stalled out won't start - Victory Forums - Victory Motorcycle Forum
post #1 of 12 (permalink) Old 03-30-2014, 08:56 PM Thread Starter
david_bailey1981's Avatar
Default 01 V92C stalled out won't start
I have a 01 V92C. I put aftermarket drag pipes on it and a generic tune on the Power Commander. When I started it up, it was popping a little and backfiring occasionally (guessing due to it needing fine tuned) took it for a quick spin and it stalled out when down shifting. When I tried to start it back up, I got a check engine warning. I also got a "5 33E" code. Does anyone have any ideas what that code means and what caused it?
2001 Victory V92C
david_bailey1981 is offline
post #2 of 12 (permalink) Old 03-31-2014, 05:45 AM
Vicbuilder's Avatar
Pull the power commander off. Test the battery. Clean the plugs, or better yet replace them. Clean the throttle body. Clean the oil temp sensor. Start it up and check for intake air leaks. Check the charging voltage.
Sounds like you have several problems. My guess is some of it was the generic Power Commander map, some is charging voltage and battery condition, and some is dirty TB's and spark plugs.
Rylan Vos
The Vic Shop, Inc
(515)-339-4313
Vicbuilder is offline
post #3 of 12 (permalink) Old 03-31-2014, 06:49 AM Thread Starter
It has new plugs and was running fine for a while before riding it. Now it won't even fire. Just rolls over. I'm going to call the Vic dealer and see if I can't get the actual code description. Everything you suggested needs done and I will do. But would it at least try to fire with those being dirty?
2001 Victory V92C
post #4 of 12 (permalink) Old 03-31-2014, 07:48 AM
Vicbuilder's Avatar
It might have something to do with the Power Commander and generic map. Either way too rich and fouled the plugs or way too lean and now it won't run.
Also make sure you connected the fuel return line under the tank.
Rylan Vos
The Vic Shop, Inc
(515)-339-4313
post #5 of 12 (permalink) Old 03-31-2014, 08:06 AM Thread Starter
Ok. It has sat all night and will have sat all day when I get home. So I will attempt to get it to fire with the PC off and see what happens. Is there a way to clear the code or will it clear once the problem is fixed?
2001 Victory V92C
post #6 of 12 (permalink) Old 03-31-2014, 08:10 AM
Vicbuilder's Avatar
It'll clear when the problem is fixed.
Rylan Vos
The Vic Shop, Inc
(515)-339-4313
post #7 of 12 (permalink) Old 03-31-2014, 08:14 AM Thread Starter
Ok. I will try those things and see what happens. Thank you very much for the suggestions.
2001 Victory V92C
post #8 of 12 (permalink) Old 03-31-2014, 08:17 PM Thread Starter
After much troubleshooting and many headaches I have tracked the issue down to probably the first thing I should've checked. It turned out to be the fuel pump fuse. Now the question is why would it blow? Would the power commander trying to draw too much fuel overload it? I want to try to avoid this in the future. Any help, as always, would be much appreciated.
2001 Victory V92C
post #9 of 12 (permalink) Old 04-01-2014, 05:05 AM
depot picker's Avatar
You probably got a wire pinched somewhere in the installation process.
depot picker is offline
post #10 of 12 (permalink) Old 04-01-2014, 05:39 AM Thread Starter
It's possible. I'll have to check before I put everything back together. Another thing I noticed was on both jugs, just above the gasket there is a tiny hole. What is that for?
2001 Victory V92C
