LED Indicator Install Help Please - Victory Forums - Victory Motorcycle Forum
post #1 of 18 (permalink) Old 03-31-2014, 05:33 PM Thread Starter
Big Tav's Avatar
Default LED Indicator Install Help Please
Hi guys, I have my HD Dealer fitting micro LED indicators to my Highball. I have the relays to help with the flash rate. I have also been told that the front indicator polarity is reversed. Is that true? What does that even mean? Wouldn't you just unbolt the old indicator and then connect the new one? Does reversed polarity mean the positive get's wired up to the negative onthe front ones?
Anything else I need to know?
2015 Highball Black - Mods being done now!
Suzuki M109R L0 - Sold
BMW K1200R - Sold
Suzuki TL1000R - Sold
2014 Victory Hammer S - Sold
2012 Victory Highball - Swept Pipes, RPW Baffles Stage 1, 02's Removed, Lloydz Timing Wheel 4+, 1/4 Turn Throttle Ring, Mini Bullitt LED Indictors, Kewl Metal Brackets, Arlen Ness Pegs & Grips, Arlen Ness Cam Cover, K&P Oil Filter, Magnetic Sump Plug, Rear Axle Covers, Black Engine Bolt Kit. - Now Sold :(
Big Tav is offline
post #2 of 18 (permalink) Old 03-31-2014, 05:47 PM
CrossRoads's Avatar
Yes, reversed polarity means it's backwards. Some genius did decide the electrical convention can be ignored, and red wires can be ground, while black wires can be positive. For the stock bulbs, it doesn't matter, because they're not polar, but LED's are polar. Tell this to the HD dealer, or they will trust convention, and assume ground is black - and you'll end up with a fried ECM.
CrossRoads is offline
post #3 of 18 (permalink) Old 03-31-2014, 05:51 PM
Originally Posted by CrossRoads View Post
ECM
Electronic Control Module, for those of us playing the home game.
post #4 of 18 (permalink) Old 03-31-2014, 06:33 PM Thread Starter
Big Tav's Avatar
Is it just the front ones that are reversed? Is it easy to check? I don't want them blaming my "must be faulty indicators" if they get it wrong and blow the ECM.
BMW K1200R - Sold
Big Tav is offline
post #5 of 18 (permalink) Old 03-31-2014, 07:45 PM
Konga63's Avatar
It should be pretty apparent when looking at the harness connectors of your front turn signals. After removing the cover of your headlamp the tech should look closely at both the right and left signal wire connections. The right is usually the side which is reversed though it could be either or even both sides. The left signal's hot wire is blue and the right's is blue/red with black being ground for both. On my bike, the right turn signal harness was reversed: the blue wire from the main harness was tied into the black wire coming off the turn signal harness.
Again, this is easy to view once you fish the connection out of your headlight bucket. The rear signal connections should be dealt w/in a similar fashion. Have the tech LOOK CAREFULLY at the connections to make sure the hot wires on one side of the connection are mirrored on the other side (i.e. blue is across from blue; black is across from black, etc.).
2007 Ness Jackpot
Konga63 is offline
post #6 of 18 (permalink) Old 04-01-2014, 07:35 AM
The bike harness side of the connector is color coded correctly, it's the OEM turn signal side of the wire connector that is reversed. So, if you remove the entire housing assembly at the connector, no worries. If you simply cut the bulb assembly off, then be aware of the crossed colors.
2011 Silver/black Vision, Ness Big Honkers, Ness Twin Sucker, PC-V w/AT, Lloydz VM1-DR cams, Lloydz Adj Intake, Lloydz Variable Timing Wheel.
2006 110" (133hp/142tq) +nitrous Kingpin (sold)
Gunslinger is offline
post #7 of 18 (permalink) Old 04-01-2014, 12:52 PM
Oldman47's Avatar
Stop messing around with wiring harness appearances. Use a volt meter on a DC scale and know what you are dealing with.
Oldman47 is offline
post #8 of 18 (permalink) Old 04-01-2014, 04:54 PM
Konga63's Avatar
Under any other electrical situation, I would agree w/you completely. However, the ACM's on these things are so fragile you can fry them very easily. I don't know why Vic even put a fuse in for the signals as the ACM goes so easily the fuse will last forever...
A forum member cooked his ACM while changing the bulb (or reinstalling it after checking to see whether it was still good). I killed my ACM merely by checking for polarity on the main harness...and, yes, I know a bit about electrics.
2007 Ness Jackpot
Konga63 is offline
post #9 of 18 (permalink) Old 04-01-2014, 05:12 PM Thread Starter
Big Tav's Avatar
Really??? You have me all worried now! I have some really cool LED indicators to put on my bike and my local Harley Dealer is going to do it for me. I'm now panicking it's going to blow or be reverse polarized or something. If it blows here in the UK I will be without my bike for months and that is no exaggeration. I thought our bikes were meant to be easier to work on than HD's?
BMW K1200R - Sold
Big Tav is offline
post #10 of 18 (permalink) Old 04-01-2014, 05:24 PM
Travis P's Avatar
Big T just tell them to ensure they check the polarity on all signal light wires prior to install... Too bad your so far away, I would do it for a bottle of Goose.
Travis P is offline
