Shift pegs - Victory Forums - Victory Motorcycle Forum
post #1 of 10 (permalink) Old 03-31-2014, 06:15 PM Thread Starter
8BallHammer's Avatar
Default Shift pegs
Are the shift pegs on a Hammer removable?
Is there a way to put the Ness shift peg on a 2012 Hammer 8 Ball?
2013 AF Green Crossed Country
TriOval slip ons
Lloydz VM-1 DR Cams
Lloydz PTS +4 degrees
PC V
Lloydz air filter
1/4 turn throttle
99.7 HP/107.2TQ
Now you know how I've felt for the last 8 years:D
8BallHammer is offline
post #2 of 10 (permalink) Old 03-31-2014, 06:37 PM
Cut, drill, tap. Sorry only way.
shanko is offline
post #3 of 10 (permalink) Old 04-01-2014, 08:13 AM
beast30's Avatar
Yes they are removable. And Arlen ness makes a threaded adapter so you can basically mount any HD shift/ brake peg to your victory pedal. And HMD520 sells them also..which are the Arlen ness ones. Once you get the old peg off I would highly recommend running a tap through the threads to cleanup any left over thread locker compound. If you heat up the pedal first it should unlock the thread locker to ease in removal.
2012 XC Imperial Blue/Blacked out, LLoyds filter, LLoyds timing wheel,
VM1 DR cams, PC5, LLoyds ECM, Big Gonzo, KM meat hook bars (internally wired), Conquest underdrive pulley, KM instrument bezels, JTD lowers with speakers, PBR300 amp with Polk 6.5, .40 cal cheese wedges, tinted turn and tail
beast30 is offline
post #4 of 10 (permalink) Old 04-01-2014, 09:45 AM
dtmmil's Avatar
Are the vic threads metric vs hd standard? Or just different size all together?
Sent from Motorcycle.com App
currently bikeless
2012 Cross Country(Imp blue)
Hawley MN(sold)
dtmmil is offline
post #5 of 10 (permalink) Old 04-01-2014, 10:14 AM
beast30's Avatar
Vic is metric HD is standard..I believe 8mm vs 5/16?
beast30 is offline
post #6 of 10 (permalink) Old 04-01-2014, 10:44 AM
Beast I believe on the XC bikes it removable but on the hammer and Vegas is is all one cast piece so you have to drill and tap or replace the whole arm
2010 Victory Jackpot
Arlen Ness Signature exhaust
Arlen Ness Beveled cam/derby covers
RSD Tracker grips
Ness V drag bars with internal wiring
Timing Wheel
Torque Tubes
VM-1 Cams
ECU reflashed
KevinC is offline
post #7 of 10 (permalink) Old 04-01-2014, 11:00 AM
beast30's Avatar
Ouch! That sucks!
beast30 is offline
post #8 of 10 (permalink) Old 04-01-2014, 11:06 AM
Originally Posted by dtmmil View Post
Are the Vic threads metric vs hd standard? Or just different size all together?
On your CC / XC / visions there metric and a good bite with a vice grips you can un screw them.
If you find a peg for h-d that hat a bolt that goes all the way threw the peg you can replace the sae with a metric. Or like they said Ness and JP and HMD sells the adapter.
post #9 of 10 (permalink) Old 04-01-2014, 11:08 AM
Sorry you would have to hack saw off drill and tap.
post #10 of 10 (permalink) Old 04-01-2014, 11:34 AM
Sman20's Avatar
Yes you do have to hack and tap. I did it on my jackpot and it came out just fine. Just be careful when tapping because you don't have a lot of room.
Sman20 is offline
