Question for those who reached 30k miles on belt - Victory Forums - Victory Motorcycle Forum
post #1 of 14 (permalink) Old 09-19-2011, 07:50 AM Thread Starter
MTVic's Avatar
Default Question for those who reached 30k miles on belt
Dealers are saying on the new bikes you are suppose to replace, not inspect and replace if necessary the belt. Why? same material as the Harley isn't it, and if an't worn, broken, cracked... why replace it?
To make it even worse they claim the pully needs to be replaced too for worn teeth that won't match belt. $1,700!
If true makes doesn't it make more sense to replace belt every 10-15k so teeth don't wear down?
Harley mechanic claims that even on the Harley, when the belt gets well over 30k and wears out, they often, but not always, have to replace pully as well.
Mike
FORMERLY 2012 Black XC Tour
2016 Honda NM4
2014 Honda CTX 700 dct
MTVic is offline
post #2 of 14 (permalink) Old 09-19-2011, 11:56 AM
Kuchera89's Avatar
im pretty sure i'd just go aftermarket then.
$5-600 for the rear. $350 for front and then a new belt is $260ish?
(i just took a quick look at conquest customs for #'s)
so $1200 and your customizing instead of maintaining...and that always hurts less to dish out $$$ for.
2007 Hammer S 100CI
S&S air cleaner, PCIII, SRVT clubs exhaust, Avon grips.
2006 Kingpin 100CI
stage 1, touring setup to come soon...nm bought a XC.
2013 Sunset red and black XC
Kuchera89 is offline
post #3 of 14 (permalink) Old 09-19-2011, 01:52 PM
Not sure about Victory but Harley rear pulleys are aluminum and should be replaced at the same time the belt is replaced. The front pulleys are steel and should last the life of the bike. I'm thinking the same goes for Victory. If you don't replace the rear pulley you will most likely have accelerated belt wear on your new belt.
2011' Cross Country BLACK
PCV with AT
Bassani 2/1 Road Rage pipe (black)
Lloydz AF, IAV & Timing gear set at +4*
Heated Grips, Heated Seat
Saddlebag bumpers
2012 XCT Windshield
Kicker spkrs. #51525
HMD XC bars 33"
HIDs(crossroads)
1985 HD FXRT 93" (Keeper)
1998 Buell S1W 1203 (sold)
1984 HD XLS 1000 (sold)
1979 Yamaha XLS 750 (sold)
VIC11CC is offline
post #4 of 14 (permalink) Old 09-19-2011, 02:01 PM
Finally a spot where I can speak with some authority....Harley belts.
Since 2003, I've ridden Harley's part time for a motorcycle escort company. Some of our spare bikes (like the one I have in my garage right now) have as many as 140k on them. All are either FLHTPs or Road King police models. They are ridden hard year around with the exception being ice on the roads. I average about 15k a year on mine.
We break belts on an average of about every 50k miles. I can only remember one time that the pulleys were changed out over the years and that was due to a rock knocking the heck out of it. I'm not saying this is the right way to do it and certainly not what the Harley dealership wants, but our average of 50k miles is pretty consistent whether it's a pulley with 50k or 100k on it.
When it comes to belts, one thing to keep in mind is that it will NEVER break in a convenient spot.
Billy
2014 XC
2006 Vegas 8 Ball
2014 Harley FLHTP (Keeping service techs busy)
Billyrides is offline
post #5 of 14 (permalink) Old 09-19-2011, 04:52 PM Thread Starter
MTVic's Avatar
I just saw a post on another site stating Harley ALSO suggest the belt be replaced along with pully at 30k. Difference is since the also have a chain in primary, total belt and pullys are $2,500! Prmary has to be torn into also for replacement.
So back to origional question, will replacing in sooner prevent having to replace pully?
Mike
2016 Honda NM4
MTVic is offline
post #6 of 14 (permalink) Old 09-19-2011, 05:37 PM
go to 75 thousand and then think about replacing the belt.
harley tells you to inspect the belt and pulley they say and victory should to clean and inspect and then maybe replace. In your manual they show what to look for on a belt. Sold my one road glide with 140 thousand on it and it had the same belt that came new with the bike.
BS you have to replace at any thing under 75 thousand.
post #7 of 14 (permalink) Old 09-19-2011, 07:38 PM
I checked through the service records of the bike I have in the garage right now. It was ridden by one of our smoother riders for 110k until the belt and belt only was replaced.
So back to your original question, if you replace pulleys as preventative maintenance, your dealer will love you.
Billy
2014 XC
2006 Vegas 8 Ball
post #8 of 14 (permalink) Old 09-20-2011, 05:29 PM
The belt on my sportster let go this summer at around 45000 kms (rock damage). I did a little search and noticed that a fair number of belts that just broke, no obvious reason, were around 30,000 (+/- 10,000) miles. When my new bike gets up around that milage I'll probably check it more frequently. There was no mention of replacing the rear sprocket when I replaced the belt.
cldiver is offline
post #9 of 14 (permalink) Old 09-21-2011, 07:54 AM
wesdalton's Avatar
Ah, for the days of the suzuki and the driveshaft
2010 X C
wesdalton is offline
post #10 of 14 (permalink) Old 09-21-2011, 02:15 PM
10,000 miles? What bikes were these breaking on, Sportys or Harleys in general?
Billy
2014 XC
2006 Vegas 8 Ball
