need help with rear turnsignal replacement - Victory Forums - Victory Motorcycle Forum
post #1 of 3 (permalink) Old 04-04-2014, 06:46 PM Thread Starter
New Member
Default need help with rear turnsignal replacement
So I am changing my rear turn signal to a LED signal and am having some issues with the switch. After replacing it and it is fully connected, when either turn signal is activated the entire bar will flash. When I just disconnect one side, the appropriate half will flash when activated. So I know it's not the LED's themselves. I contacted the seller of the light and they told me that it needs a flasher relay. The only question was if it will be a 2 or 3 pin. They told me to remove the seat and turn the signal on and feel for the part that is ticking with the indicator flashing. I did this and located the ticking piece but when I disconnected it to look for the number of pins I found much more than just 2 or 3. It was more like 12. After seeing this I am wondering if I had the right piece. Please help because as the weather is finally getting better up here in Jersey, I would like to have this ready asap.
Attached is a picture of the light, the piece they told me to locate and the tag on the wire of the same piece.
C-LoNico is offline
post #2 of 3 (permalink) Old 04-04-2014, 07:42 PM
Konga63's Avatar
Please let us know your model and year to better understand your dilemma. Thanks.
2007 Ness Jackpot
Konga63 is offline
post #3 of 3 (permalink) Old 04-04-2014, 07:59 PM Thread Starter
New Member
Sorry it is a 2013 high-ball.
C-LoNico is offline
