How often to use fuel injector cleaner? - Victory Forums - Victory Motorcycle Forum
post #1 of 34 (permalink) Old 04-04-2014, 07:46 PM Thread Starter
FISHDAWG's Avatar
Default How often to use fuel injector cleaner?
I did a search and came up short on how often to add fuel injector cleaner to a tank of gas? I would think it would be different form a car, but thought i might tap into some of the wisdom here on the forum. Any suggestions? or routines? Maybe at each oil/filter change?
FISHDAWG is offline
post #2 of 34 (permalink) Old 04-04-2014, 08:01 PM
depot picker's Avatar
Never added fuel injector cleaner to anything.
depot picker is offline
post #3 of 34 (permalink) Old 04-04-2014, 08:46 PM
Banned
Techron, two tanks worth at the beginning of the season.
63625 is offline
post #4 of 34 (permalink) Old 04-04-2014, 09:56 PM
Oldman47's Avatar
I only have 11700 miles on my '13 Vision so I have had no need for an injector cleaner yet.
Oldman47 is offline
post #5 of 34 (permalink) Old 04-04-2014, 11:50 PM
Motorbikerx's Avatar
You can but I wouldnt, submersible fuel pumps have carbon brushes in them...what does injector cleaner attack?..thats right.... Carbon
..think about it
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
Motorbikerx is offline
post #6 of 34 (permalink) Old 04-05-2014, 03:05 AM
spikey2's Avatar
Default not that the carbon brushes
run in the petrol-cleaner mixture .....
Injector cleaner (so i've heard) is very corrosive, to do its job. Only use it if you have to ....
..think about it
spikey2 is offline
post #7 of 34 (permalink) Old 04-05-2014, 08:11 AM
dtmmil's Avatar
I add a little marvel mystery oil once every few tanks, maybe an ounce to a full tank. Run good gas is more important, dont run ethanol if you can help it, find a gas station that you have good luck with and stick with it.
Sent from Motorcycle.com App
currently bikeless
2012 Cross Country(Imp blue)
Hawley MN(sold)
dtmmil is offline
post #8 of 34 (permalink) Old 04-05-2014, 09:31 AM
and don't fuel up while the petrol stations tanks are being filled.
Victory Vegas 2010
" " 495 cams
" " TorqueTubes
" " Primary plate
" " IAV
RPW Slash pipes
Kingpin USD Forks
18" XC front wheel
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
post #9 of 34 (permalink) Old 04-05-2014, 09:51 AM
LILMAGS500's Avatar
I have used the Polaris fuel injector cleaner , (also recommended for Victory) a couple of times . Got it right from my Victory dealer .
LILMAGS500 is offline
post #10 of 34 (permalink) Old 04-05-2014, 10:44 AM
Pop
..think about it
I thought about it.
I think that if your pump motor brushes are exposed to your fuel flow, whether you have a cleaning agent mixed in will probably not affect the explosion much. At least, not to the point where the insurance
company can use fuel injector additives as a reason to refuse to pay for your groin reconstruction surgeries.
Red.
2012
Cross Country Tour.
We can't help it
We just keep moving
It's been that way since long ago
Since the stone age chasing the great herds
We mostly go where we have to go
That was written by James McMurtry
Pop is offline
