pcv or flash - Victory Forums - Victory Motorcycle Forum
post #1 of 55 (permalink) Old 04-13-2014, 06:40 AM Thread Starter
Default pcv or flash
I put new pipe on my crossroads it already had a hi flow filter ( not Lloyd's ) disconnected the O2 sensors but she is running very lean. Plug is white when pulled. Do I need to flash the ecu if I put a PCV on.
KPR108 is offline
post #2 of 55 (permalink) Old 04-13-2014, 06:46 AM
TNXR's Avatar
Flash or PCV either one will work for you. Or you can just put the regular filter back in and plug you 02's back up. I have been running mine with just gutted pipes for over a year with no problems.
2011 Cross Roads Sunset Red
TNXR is offline
post #3 of 55 (permalink) Old 04-13-2014, 06:49 AM
Vicbuilder's Avatar
No, you don't need to flash the ECU if you put a PCV on.
Rylan Vos
The Vic Shop, Inc
(515)-339-4313
Vicbuilder is offline
post #4 of 55 (permalink) Old 04-13-2014, 09:44 AM
CrossRoads's Avatar
Yes, what Rylan said.
Plugging the OČ sensors back in will allow the bike to run as lean as the Government intended it to run. I would leave the OČ sensors disconnected, unless you're trying to set new EPA records.
CrossRoads is offline
post #5 of 55 (permalink) Old 04-13-2014, 09:55 AM Thread Starter
I think I'm going to do the PCV as later I will be adding a Lloyd's filter.
Thanks for the info
KPR108 is offline
post #6 of 55 (permalink) Old 04-13-2014, 10:25 AM
LILMAGS500's Avatar
Thanks for the info
PCV PCV PCV PCV
LILMAGS500 is offline
post #7 of 55 (permalink) Old 04-13-2014, 10:48 AM
How many miles on the plugs?
What is your gas mileage? Between 40 and 44 is not lean more like average.
post #8 of 55 (permalink) Old 04-13-2014, 10:59 AM Thread Starter
Just put new plugs in did 30 miles found out previous owner disconnected the 02s sensors. Pulled plugs were black. Put the new pipe on left 02's off did 2 miles checked they were white.
KPR108 is offline
post #9 of 55 (permalink) Old 04-13-2014, 12:14 PM
dtmmil's Avatar
30 miles isnt long enough on new plugs especially if you put ngks back in, they take forever to color, if the old ones were black your rich.
currently bikeless
2012 Cross Country(Imp blue)
Hawley MN(sold)
dtmmil is offline
post #10 of 55 (permalink) Old 04-13-2014, 12:17 PM
CrossRoads's Avatar
No way! What color where the plugs, when brand new? White? Oh, yeah, it would take more than 2 miles for them to change color.
