05 vegas tail light inop - Victory Forums - Victory Motorcycle Forum
post #1 of 11 (permalink) Old 10-01-2011, 01:04 PM Thread Starter
kidwell03's Avatar
Default 05 vegas tail light inop
Alright guys, I know im not the first. how did you change out the bulb in the tail light? My running light and brake light aren't working, blinkers work. Already checked fuses and voltage( 20v after the connector). To me it looks like you have to order the whole tail light assy.
2005 Vegas 8 Ball (MY BABY)
1996 Honda Shadow, cut, sawed, hard tail, ratted bobber (WHITE TRASH Build)
2011 XC -Destroyed by a kids Chevy Cruze
2012 XC
2002 HD Electra Glide Classic sold
kidwell03 is offline
post #2 of 11 (permalink) Old 10-01-2011, 01:12 PM
muzz1447's Avatar
you are correct, you have to order a new one! No way to change them unless u want to rig something up
muzz1447 is offline
post #3 of 11 (permalink) Old 10-01-2011, 01:24 PM Thread Starter
kidwell03's Avatar
what can I rig up?
2012 XC
post #4 of 11 (permalink) Old 10-01-2011, 01:25 PM
Nycskool50's Avatar
Default Chrome Glow...
Check out www.chromeglow.com. They have a replacement/upgrade taillight available for like 70 bucks. All it is basically is 25 LED's wired to a round board. Get yourself a hole-saw, make a hole in your taillight housing and epoxy into place. Wire it up to your tail light leads and you are good to go. Took me a half hour to fix mine.
2007 Hammer Premium
Nycskool50 is offline
post #5 of 11 (permalink) Old 10-01-2011, 01:45 PM Thread Starter
kidwell03's Avatar
Thanks just ordered that, saved me some money bro so I appreciate it!!
2012 XC
post #6 of 11 (permalink) Old 10-01-2011, 02:18 PM
Tarzan's Avatar
I had one of those round units that mounts in a hole you cut in the back of the light ,on my Pin. People kept telling me they could hardly see my brake light in the day time.I just replaced it about a month ago with an 09 tail light and the difference is huge.
'14 Ness XC
Tarzan is offline
post #7 of 11 (permalink) Old 10-01-2011, 04:42 PM
NOEMTZ's Avatar
Hopefully that will work for you....if you decide to do the actual much brighter conversion....I may be able to help.
www.noemtz.com
NOEMTZ is offline
post #8 of 11 (permalink) Old 10-01-2011, 05:07 PM
Nycskool50's Avatar
Mine works fine...bright enough I think and much brighter than the one LED set-up that was standard. I would like to upgrade to a newer style light one day but at over two bills with the 12 volt converter, I could find better ways to spend the money. To each his own I guess
2007 Hammer Premium
post #9 of 11 (permalink) Old 10-03-2011, 07:13 PM Thread Starter
kidwell03's Avatar
I get the new lights in tomorrow and just want to make sure this is simple wire and go. I don't need anything more than what comes in the mail tomorrow?
2012 XC
post #10 of 11 (permalink) Old 10-03-2011, 07:20 PM
Nycskool50's Avatar
All you need is a hole saw and a drill. Make sure the hole saw has the fine teeth on it for plastic. The ones with the bigger teeth will make a mess.
2007 Hammer Premium
