04 Vegas Brake Light Issue - Victory Forums - Victory Motorcycle Forum
post #1 of 10 (permalink) Old 04-22-2014, 01:54 PM Thread Starter
VictoryGuy's Avatar
Question 04 Vegas Brake Light Issue
Last night while riding with a buddy he noticed my brake light was not working on my 2004 Vegas. The tail light is lit but neither the foot pedal nor the hand brake light up the brake light. I checked wiring under the back fender after reading about bottoming out issues and everything seems in tact. I also checked fuses, all of which appear to be functioning.
Has anybody else had this issue? I have very minimal skills mechanically/electrically, but I thought I'd throw this up to see if there's anything I can do before having to bring it in...
Thanks for reading!
VictoryGuy is offline
post #2 of 10 (permalink) Old 04-22-2014, 02:34 PM
Have you checked the light to see if its working.
With a meter you could check power at the taillight to see if your getting power to the light.
If your getting power at the light then the light must be bad
post #3 of 10 (permalink) Old 04-22-2014, 04:14 PM
Victory guy, your checking the wiring and getting results that indicate "it seems" and "appears" is not going to help you if you want to improve your skills and get into any level of proper troubleshooting. I recommend you get yourself a cheap electrical meter so you "know" what switches are working where the power is getting to. It will help you immensely in your understanding of the wiring, fault finding capabilities and reducing the time it takes to get back on the road.
53canuck is offline
post #4 of 10 (permalink) Old 04-22-2014, 07:47 PM
depot picker's Avatar
Change the bulb.
depot picker is offline
post #5 of 10 (permalink) Old 04-22-2014, 08:11 PM
Ghost_Rider's Avatar
If you plan on doing most of your work on the bike yourself, then I would recommend spending a little extra and getting a good multimeter with volts, ohms, and so on. Fluke makes a good one, I have a blue point and it does everything I need it to. but as for the light, the first thing I would do is pull the bulb and see if its good. look closely at both filaments. If the bulb is ok, start checking power and ground
2003 V92C
Wrapped RPW Slash pipes
K&N air filter
Stebel Nautilus
Viking saddlebags
16" apes
Ghost_Rider is offline
post #6 of 10 (permalink) Old 04-22-2014, 10:37 PM Thread Starter
VictoryGuy's Avatar
Thanks for your input, good stuff, but like i said before, the tail light is lit. The tail light and brake light are one bulb. So it's not an issue of burnt out bulb. I took it all apart tonight. I unplugged the tail light, replugged it in, and the brake light worked! But, when i would fiddle with and press on the connector plug (part name??) it would go in and out. I'm going to try and adjust the pins to get a better connection and throw a little dielectric oil on it to see if that solves the shorting out...
2004 Vegas
Arden Hills, MN
post #7 of 10 (permalink) Old 04-23-2014, 05:17 AM
Encmerk's Avatar
Victoryguy,
You are correct in saying both are on the same bulb, what you need to understand is that there are two filaments in that bulb. It is possible to have one blow without the other being affected. In addition, moving the bulb like you did can get the filament to touch and work temporarily. Please invest in a multimeter for your future troubleshooting growth. In addition, sometimes a visual inspection will not detect a failed filament. On a 2.00 bulb, I would do a simple swap to see if problem is resolved. Good luck.
Master Sergeant, USMC Retired
2002 HD Sportster 1200 Custom -sold
2013 XCT Boardwalk Blue picked up 1/21/2014
Vance and Hines hi output slip-ons
Lloydz hi-flow air filter
PCV w/AT
Lloydz ATS @ +4
CrossRoads HID's Hi and Low
Havelock, NC
Encmerk is offline
post #8 of 10 (permalink) Old 04-23-2014, 09:28 AM Thread Starter
VictoryGuy's Avatar
I see. Good to know, thanks!
2004 Vegas
Arden Hills, MN
post #9 of 10 (permalink) Old 04-23-2014, 10:53 AM
so do you have a normal taillight bulb like what you can buy from auto store or do you have the factor LED.
The vegas comes from the factor with a LED taillight
post #10 of 10 (permalink) Old 04-23-2014, 11:51 AM Thread Starter
VictoryGuy's Avatar
It's LED. I cleaned the connectors, applied some dielectric grease, reassembled everything and it functions properly. Not sure if this is a long term solution or just a temporary fix, but I'm good to ride for now...
2004 Vegas
Arden Hills, MN
