What lube to use on my clutch cable? - Victory Forums - Victory Motorcycle Forum
post #1 of 6 (permalink) Old 10-11-2011, 08:03 AM Thread Starter
Default What lube to use on my clutch cable?
I'm wondering, what's the best type of grease to use on my cable ends? What about inside the cable housing?
2011 Vegas 8-Ball
Ness Fly Bars
jimmy77611 is offline
post #2 of 6 (permalink) Old 10-11-2011, 08:21 AM
Default cable lube
jimmy: i use a good quality moly lube (sparingly) on the cable ends. most any good quality lube that you can spray down the cable housings will work well. be sure to take your time and spray alittle at a time until you see lube at the lower end of the cable housings. some folks like to use a fixture called a cable oiler/lube sleeve. i never had much luck with them. also be careful of dry graphite and a product called dry slide (graphite in a solvent solution that evaporates) these can build up in the cable housings and actually bind the cable operation.
2002 v92c deluxe/ 1970 flh bobbed
swatsonv92 is offline
post #3 of 6 (permalink) Old 10-11-2011, 09:19 AM Thread Starter
I have some "Cable Life" lube that I used to spray inside the housing on my old bike. It's sort of a clear thin liquid, some sort of silicone or something I think. Would this be good for the inside of the housing? I think I'll pick up some Moly for the ends. Thanks for the advise.
2011 Vegas 8-Ball
Ness Fly Bars
post #4 of 6 (permalink) Old 10-11-2011, 11:13 AM
busajack's Avatar
From the Vic maintaince service manual.
CABLE INSPECTION/Lubrication.
NOTE: Control cable casings are lined with a low friction sleeve and are factory lubricated for reliable operation. Periodic lubrication of cables is not required and could be detrimental to cable performance. Only cable ENDS must be periodically inspected and lubricated in accordance with the Periodic Maintenance Schedule.
I have to grow old but I don't have to grow UP.thumb up. 2010 Jackpot.
busajack is offline
post #5 of 6 (permalink) Old 10-11-2011, 04:02 PM
Goatlocker95's Avatar
I use white lithium grease on the ends only. Like busajack pointed out, you do more harm than good lubing the newer cables.
2014 Indian Chieftain
Goatlocker95 is offline
post #6 of 6 (permalink) Old 10-12-2011, 07:01 AM
Default lubing cables
yeah i have to say i don't know what the factory recommends on late model stuff but i ride a 10yr old v92 in any weather and you can believe the cables need periodic maintenance/lube. white lithium grease works well most of the time although i think it has a tendency to clump moreso than good moly bearing lube.
