Shifing issue, fix, and possible improvement - Victory Forums - Victory Motorcycle Forum
 5Likes
post #1 of 77 (permalink) Old 04-29-2014, 04:51 PM Thread Starter
half_crazy's Avatar
Default Shifing issue, fix, and possible improvement
I noticed on my last long ride that if I wind the bike out past 5000 rpm it wouldn't shift. The shifter moves up, but no pookie... still in the same gear. In normal riding you would never know, but it seems the shift ratchet just slips when you're honkin' on it.
I decided to replace the whole shifting system AND I picked up a 'shift kit' from Factory Pro that is supposed to improve shifting on these things.
The Victory parts, including a Cometic gasket for the primary cover cost $198.00
The Factory Pro parts were $119 + shipping, which seems like a lot for that little bit of sh!t... it better shift good!
All will get installed this weekend. The clutch has to come out to get to the little arm, spring and star. The ratchet can be done just by removing the primary cover. I could probably have just changed the ratchet and it would be fine again... but me being me... not gonna happen. I will post a report after it's done and I ride it some.
2006 Victory Kingpin
half_crazy is offline
post #2 of 77 (permalink) Old 04-29-2014, 05:14 PM
CrossRoads's Avatar
So this is something that has recently developed, or you would've noticed it before, right? Is the oil approaching its end life?
CrossRoads is offline
post #3 of 77 (permalink) Old 04-29-2014, 05:28 PM Thread Starter
half_crazy's Avatar
Oh, I would have noticed it right off and the oil is fresh. I think it has something to do with the 80,000 miles on the odometer.
post #4 of 77 (permalink) Old 04-29-2014, 05:55 PM
Oldman47's Avatar
Let us know how that works out HC. There is always room for us to learn.
Oldman47 is offline
post #5 of 77 (permalink) Old 04-29-2014, 06:00 PM
Pretty lucky if it was a h-d all the gears would have to come out. Its the first part in and the spring does break and its the last thing out.
Good Shifting to You
post #6 of 77 (permalink) Old 04-29-2014, 09:15 PM
Mr_Buzzcut's Avatar
Im really interested to see how this works for you.
2008 Hammer S
300mm Fat tire
USMC 87-92
Mr_Buzzcut is offline
post #7 of 77 (permalink) Old 04-30-2014, 02:45 AM Thread Starter
half_crazy's Avatar
Now that I think about it... there were a couple of races where I couldn't get the bike to shift from 3rd to 4th... I blamed it on my crippled up leg/foot, but now I'm not so sure it wasn't the bike.
post #8 of 77 (permalink) Old 04-30-2014, 03:10 AM
Motorbikerx's Avatar
interesting HC let me know how it goes thanks.
mu 2010 Vegas has shifting issues occasionally going into second and third if its not put in solid...a lazy shift and it'll jump out sometimes.
Combine that with a heavier than normal clutch and it can be a chore to ride at times.
I plan on keeping this bike and am slowly bringing the Torque and Power up, and I'd like to get the clutch and gears working as well as the rest of the bike works.
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
Motorbikerx is offline
post #9 of 77 (permalink) Old 04-30-2014, 04:21 AM Thread Starter
half_crazy's Avatar
My clutch was a bear... a new clutch cable did wonders. It's still a 'man's clutch' with the stiff spring in there, but it's a lot better than it was.
post #10 of 77 (permalink) Old 04-30-2014, 09:18 AM
Pop
Pardon the editorializing HC but you know how I get.
Anyway, this is a case of a motorcycle that, through many miles of use near, at or beyond the manufacturer limits appears to be revealing wear characteristics that otherwise would not be known. First I heard of it out of the little I know about Vic gearboxes so I'm thinking it's not a common issue or cause for concern. Maybe a fluke but it may be a harbinger of things to come for many Vics of a certain mileage or a certain number of shifts.
While some shake their righteous fingers when throttle jocks do what they do, it's the pushers that find out what happens to the machine at it's limits. That info helps everybody, even Ma Vic if she's willing to pay attention. If this is happening to HC at 80k maybe it's happening to Grandpa at 100 and Grandpa can use that info if he wants to.
Cool thread.
SkInM4N likes this.
Red.
2012
Cross Country Tour.
We can't help it
We just keep moving
It's been that way since long ago
Since the stone age chasing the great herds
We mostly go where we have to go
That was written by James McMurtry
Pop is offline
