Installing VFC3 Sunday, need a little advice please - Victory Forums - Victory Motorcycle Forum
post #1 of 34 (permalink) Old 05-02-2014, 09:04 PM Thread Starter
Rocksalt's Avatar
Lightbulb Installing VFC3 Sunday, need a little advice please
Hey everyone, I'm putting the VFCIII on my Vegas 8 ball 2014 on sunday and I could use some advice.
My mechanical wherewithal is at exhaust installation and removal so far.
The only thing that makes me anxious about the VFC install is the removal of the tank. I've never removed a tank before so any steps, tips and/or advice would be greatly appreciated.
Thank you!
2014 Vegas 8 Ball
Conquest Customs 2 into 1
VFCIII
San Diego, CA
Rocksalt is offline
post #2 of 34 (permalink) Old 05-02-2014, 09:31 PM
This is no problem. Just go slow. The only issue with the tank is squeezing the fuel line connector to get it off the tank nipple. There are two sides that have to be squeezed in to allow you to remove the line from the nipple. If you are forcing it then you have not squeezed it correctly. Do not force anything. When you are pulling the tank there are two vacuum lines that you just pull them apart. All is good. On installing the VFC I had a problem getting the injector to seat on the back cylinder. The problem was that it only will seat when it is not twisted. I hope I am explaining this correctly. The injectors will press down when they are exactly in the correct position. Again do not force them. Just move the injector a little right or left and it will seat with a click sound. Anyway take your time go slow and do not force anything and all will work well. Best
John Indianapolis IN
2012 cross country, Adam bomb mufflers
2007Kingpin (sold)
johnah5 is offline
post #3 of 34 (permalink) Old 05-02-2014, 09:42 PM
Motorbikerx's Avatar
I will add to the above that if you disconnect the fuel line connector behind the rhs cheesewedge first it will give you more room to lift the rear of the tank and gain access to the fragile connector on the bottom of the tank.
I just R and R'd my tank early this morning so its all fresh in my mind.
its lot easier with an almost empty tank too...mine was full when I did it very late last night....I actually left it connected at the base of the tank until I had the tank right off and resting securely on a panel stand.
Then I removed it.
on refitting I placed the fuel pipe where it sits the fitted the front of the tank, supporting the rear then with one hand I carefully clicked the undertank connector back into place...dont forget the fuel gauge connector too, then with tank sitting flat I reconnect behind the cheesewedge.
dont rush it and remember to Breathe
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
Motorbikerx is offline
post #4 of 34 (permalink) Old 05-03-2014, 08:04 AM
started my bike up at lunchtime to head out for a ride,
it ran real rough and dumped a lot of fuel over the engine as it stopped.
Suspected broken nipple under tank where connector goes
Luckily it was just a bad connection, hadnt been pushed on quite hard enough....bike had run earlier before tank was bolted in place fully.
seems the fuel line mustve dislodged itself as the tank was bolted down...made a dangerous mess!
Rectified the problem and went for a good ride
so watch those fittings go back on properly
Victory Vegas 2010
" " 495 cams
" " TorqueTubes
" " Primary plate
" " IAV
RPW Slash pipes
Kingpin USD Forks
18" XC front wheel
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
post #5 of 34 (permalink) Old 05-03-2014, 09:49 AM
LILMAGS500's Avatar
You need to hear a pronounced SNAP to know for sure the line is properly connected , with no snap , goes much fuel on your motor , Ask me how I know . Also MBX is correct , it makes it easier to remove if you disconnect also behind the cheese wedge at the fuel rail .
LILMAGS500 is offline
post #6 of 34 (permalink) Old 05-03-2014, 04:19 PM
spanknut24's Avatar
what keeps the fuel from spilling allover when you disconnect the line?Is there a valve to shut off or somethig. Im gettin ready to take mine off to run the cable for my usb charger..
06 Kingpin..
K&N air filter
Victory Drag Pipes
ATS @ +4
VFC III
Tuned by KMC
08 vision premium.. totaled :(
06 kp traded in.
04 vegas lost in flood 2010.
06 hyosung traded in for vegas.
spanknut24 is offline
post #7 of 34 (permalink) Old 05-03-2014, 04:41 PM
dtmmil's Avatar
it only leaks out a little bit, shove a rag in under the connection when you disconnect.
currently bikeless
2012 Cross Country(Imp blue)
Hawley MN(sold)
dtmmil is offline
post #8 of 34 (permalink) Old 05-03-2014, 06:39 PM
Yeah as dtmmil said.
Victory Vegas 2010
" " 495 cams
" " TorqueTubes
" " Primary plate
" " IAV
RPW Slash pipes
Kingpin USD Forks
18" XC front wheel
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
post #9 of 34 (permalink) Old 05-03-2014, 06:56 PM
gizmo5's Avatar
I installed my EJK controller (same thing) without removing my tank and disconnecting my lines. I had a full tank and didn't wanna mess with it, nor did I have patience to run it empty lol. I made it work though, so it IS possible.
13 High Ball
Bassani Pro Street Turnouts
EJK Controller
gizmo5 is offline
post #10 of 34 (permalink) Old 05-03-2014, 07:23 PM
SilentUnicorn's Avatar
The hardest part (if you have a stock airbox) will be the front injector plug. Getting it off is not too bad- putting it on ...well that is a different story. I made a hook out of a coat hanger to coax it into place and then some long needle nose to assist in getting it lined up and locked in. Be sure to re-seat the little red tabs.
m
'12 Vegas, 78 Bonneville, 69 BSA project.
SilentUnicorn is offline
