Low cost mods + PCV? - Victory Forums - Victory Motorcycle Forum
post #1 of 9 (permalink) Old 05-05-2014, 12:13 PM Thread Starter
Dos_Equis's Avatar
Default Low cost mods + PCV?
Hello Team:
Some questions.
New owner here. Being with the bike (2013 CC Sunset Red) for exactly a month and so far 1400 miles in the odometer.
Will like to make the bike louder without expending in new mufflers. Planning to do the mods mentioned on:
https://www.victoryforums.com/showthread.php?t=4440
1. Replace air filter with a high flow washable filter.
2. Remove foam strip under tank for air intake.
3. Disconnect O2 sensors
4. Drill a 1-1/8" hole in the plate approximately 18" from the outer end of the pipe.
1- With just the mods mentioned above will I still benefit from installing a PCV?
2- Will the PCV work with just the mods mentioned above?
I am not looking for extreme power, I just want the bike to be louder. Being upshifting at around 3500 RPM's. At around 4000-4200 RPM's the bike feels like is not "breathing" right, hard to explain.
Besides the 1 - 1/8 hole in the inner plate, if I also drill holes on the sides of the exhaust, will this affect the performance of the bike?.
Thank you very much for any advice and input.
2013 Cross Country (Sunset Red)
-- Rusty Jones Customs mod mufflers, Power Commander-V, Lloydz Hi-Flow Air Filter, Lloydz ATS @ 6+, Tarzanz Bagger barz.
Houston, TX
Dos_Equis is offline
post #2 of 9 (permalink) Old 05-05-2014, 02:44 PM
dtmmil's Avatar
best bang for buck, timing wheel , if your going to do the filter get lloydz, dont bother with the other one, to me drilling the baffle was a waste of time and ended up with glasspacks, pcv and at or pcv and dyno will help even a stock bike.
currently bikeless
2012 Cross Country(Imp blue)
Hawley MN(sold)
dtmmil is offline
post #3 of 9 (permalink) Old 05-06-2014, 08:39 PM
Jckercheval's Avatar
Ditto that! I left my XCT in stock condition for the first year. I did unplug the O2 sensors. I was disappointed that my Vulcan 900 had more zip ( I do have a hi-flow air intake, open pipes and a fuel controller on it...but for cryin out loud...the Vic has double the cc's). The engine always felt like it was holding back. The Lloydz ATS at $142 cured that sluggish take-off and woke her up. Now I'm ready to add some more upgrades. Only problem.....well, like Van Halen says....I can't drive 55. It's too easy to go fast, because the Vic is such a smooth ride. Rolled onto the interstate last night from the ramp and when I looked down she was in triple digits. Oops! Sooner or later that's gonna get me in trouble. Spend the $142, you'll be impressed with the big performance difference for that much money.
2013 Cross Country Tour & 2006 Vulcan 900 Classic,
Lloydz ATS Wheel
Lloydz Air Filter
Witchdoctor Voodoo HP Pipes
RF PBR300 with Polk MM531's
I love my wife....and motorcycles. She understands (most of the time)!
Coming to you from lovely Clear Spring, Maryland
Jckercheval is offline
post #4 of 9 (permalink) Old 05-06-2014, 09:00 PM
dtmmil's Avatar
i did the same thing, then had to ditch a cop , not sure what 110 in a 65 would be in MN for a ticket, but wasnt going to find out either!
currently bikeless
Hawley MN(sold)
dtmmil is offline
post #5 of 9 (permalink) Old 05-06-2014, 09:47 PM
It looks like careless driving. They will plead the fine down. But the insurance company will make a fortune.
1981 Honda cx 500
1999 yamaha fzr600
1980 Honda cb750
1978 Xs750
2003 yamaha vstar
2005 HD softail
2001 Victory 92c
2012 HD Road King
2013 ZNESS XC RPW's victory stage 1 air cleaner stage 1 download, Cobra FI2000 power pro, timing wheel +4
jrp267 is offline
post #6 of 9 (permalink) Old 05-08-2014, 10:08 AM Thread Starter
Dos_Equis's Avatar
Default Update 1
Hello Team:
Last night did steps 3 & 4 (Disconnect O2 sensors and drill a 1-1/8" hole in the plate approximately 18" from the outer end of the pipe).
I also drill 5 (1/4") holes on the side. No idea if that will be louder. I took a video of before and after the drilling but still trying to figure out how to post them on-line. The bike sounds a bit louder at idle. Still need to try it on the open road.
Trying to drill the hole with Lenox 1 - 1/8 hole saw from the outlet didn't work. the hole-saw does not go all the way to the plate. seems like on the inside it goes narrow. Remove the pipes and drill from the inlet side and it was more easy.
Any idea how to remove foam gasket for the air filter? I don't feel comfy removing the gas tank.
Houston, TX
post #7 of 9 (permalink) Old 05-08-2014, 11:13 AM
Not a very good photo but this is what a baffle looks like
post #8 of 9 (permalink) Old 05-08-2014, 11:39 AM Thread Starter
Dos_Equis's Avatar
Yes I have see it before. How do you remove it? Seems like some parts are welded to the walls of the muffler.
Houston, TX
post #9 of 9 (permalink) Old 05-09-2014, 10:25 AM Thread Starter
Dos_Equis's Avatar
Finally was able to take the bike for a test ride last night.
The sound is NOT loud at all. (perhaps I am becoming deaf?). I can only hear the engine from 4000RPMs and above. Very little backfiring on deceleration and that was only at the beginning.
Thinking about drilling the side holes all the way trough the other side trough the inner core and baffles and see if that makes it louder.
1 - How do I know how leaner is the bike running?
2 - If I add the Hi-Flow Lloydz filter will that make the bike leaner?
3 - How can I make it "richer" with out adding a PC-V?
__________________
Houston, TX
