Benefits of installing a Lloyds High Flow Filter - Victory Forums - Victory Motorcycle Forum
post #1 of 42 (permalink) Old 05-06-2014, 09:36 PM Thread Starter
Smile Benefits of installing a Lloyds High Flow Filter
So I recently installed a brand new Lloyds High Flow Air Filter. I am just wondering what sort of benefts should I be expecting? I do hear the air being sucked into the filter. In terms of better gas milage should I see any benefits with this addition?
Rocketman is offline
post #2 of 42 (permalink) Old 05-07-2014, 12:06 AM
ndabunka's Avatar
No better fuel economy. However, you DO get about 4HP & aroun 5TQ more out of the beast!
It's not just any victory.... It's MY Victory!
2011 Victory Ness Cross Country #120
Ness Thunderheaders
Ness Knurled Highway Pegs/KwelMetal Brackets
Ness Radius laydown license
Chrome CAM Tension Covers
Red Engine Bolts
Madstad System
DIY Garage Door Opener
Victory Chrome Saddle Bag Lid Rails
Küryakyn Upper Fork Shrouds
Küryakyn Lower Fork Covers
Power Commander V Tuner
Power Commander AT-300
Hertz HCX 165s Speakers
JL Audio HX280/4 Bridged 140w
ndabunka is offline
post #3 of 42 (permalink) Old 05-07-2014, 03:17 AM
half_crazy's Avatar
More than that... but you have to TUNE IT for the additional airflow.
2006 Victory Kingpin
half_crazy is offline
post #4 of 42 (permalink) Old 05-07-2014, 04:48 AM
Default Revs
Should have fitted lloyds fuel controller while you had the tank off its easy to fit using the instructions and comes with base line settings for various set ups since fitting these two upgrades plus Lloyds adjustable timing wheel I have found myself running the bike higher up the rev counter than before so fuel consumption is greater but so is the smile on my face.
london Britain 2011 Hammer S Vic st1 Loydz airbox fuel controller and ATW Banidt seat conquest custom engine covers chamfered footrests and MSD coils progressive rear shock.
surly is offline
post #5 of 42 (permalink) Old 05-07-2014, 08:44 AM Thread Starter
Default Lloydz High Flow Air filter
My goal of purchasing the Lloydz High Flow air filter was to improve gas millage . My 2013 CCT as lots of humph aleady and lots of get up and go , don't really need much more.
Put on over 12,000 kms in my first season of riding it last year and loved it. Looking forward to adding many more kms once this Canadian winter is over.
post #6 of 42 (permalink) Old 05-07-2014, 09:22 AM
ammo_umb's Avatar
My mpgs around 5000' haven't changed but it takes less throttle while running. Unfortunately my riding is mostly at 5000' and up so your results may not be the same.
Retired USAF, IYAAYAS!
ammo_umb is offline
post #7 of 42 (permalink) Old 05-07-2014, 05:33 PM
Jckercheval's Avatar
I'm just getting ready to install mine, and I think the results will be the same. Riding at higher RPM's = higher smile factor (until a cop is around)....but lower MPG factor. After my ATS install, I can't control my right hand. I'm sure that will get even worse after the PCV and Lloydz hi flow filter install.
It's always about the right hand with guys! For teenagers, its one thing.....for us middle-age guys with a bike...it's entirely different, but still kind of the same!
2013 Cross Country Tour & 2006 Vulcan 900 Classic,
Lloydz ATS Wheel
Lloydz Air Filter
Witchdoctor Voodoo HP Pipes
RF PBR300 with Polk MM531's
I love my wife....and motorcycles. She understands (most of the time)!
Coming to you from lovely Clear Spring, Maryland
Jckercheval is offline
post #8 of 42 (permalink) Old 05-07-2014, 05:39 PM
vindex1963's Avatar
Looking forward to hearing how it went and the results.
1/4 turn throttle ring
Tank riser
VM-1 DR cams
Timing wheel +4
Lloydz high-flow air cleaner
Bassani baffled OEM mufflers
PC-V 118hp 116tq
vindex1963 is offline
post #9 of 42 (permalink) Old 05-08-2014, 09:59 PM
The Lloydz air filter for the X bikes are a performance item like most of his products.
You probably won't see any benefit until you twist the throttle at a time when it really counts but just the air filter isn't enough. You must have an exhaust and tuner to match up with it. Get the drop in cams and timing wheel to really wake the beast up and put a grin on your face from ear to ear all day long.
post #10 of 42 (permalink) Old 05-09-2014, 08:42 AM
Default The same
the results will definatley be the same right down to the stupid grin on your face I also own a honda crosstourer which is faster (much) and handles better (much) and is comfier but my hammer still gets used more the feel good factor is through the ceiling.
You have covered teenagers and middle aged men how about us old men like 63 is it ok to have both things?
surly is offline
