Difference in stage 1, 2, 3, etc? - Victory Forums - Victory Motorcycle Forum
post #1 of 14 (permalink) Old 05-12-2014, 07:30 PM Thread Starter
bsbabcock's Avatar
Default Difference in stage 1, 2, 3, etc?
I have a fairly good idea some level of upgraded air filter and a muffler or full exhaust, and either a flash or tuner makes up a textbook stage 1.. So what's stage 2, then 3, to Stage n?
I imagine at some point a larger bore or stroke or both you be in there somewhere as an upper stage of some kind. Or even forced induction super or turbo charging etc.
I'm doing VM1 cams, Lloydz x bike filter, adj timing wheel, PCV and dyno tune. What "stage" would that be, for example.
Granted I imagine there's some blurring with some combination of what is or isn't installed with a particular build.
Just wanted a quick Q&A on the Victory performance upgrade stages. Thought it'd be interesting.
Sent from Motorcycle.com App
2013 Hard-Ball - Lloydz VM1-DR cams, air filter, timing wheel, PCV, properly tuned at KMC
Master, Biltmore Lodge #446, AF&AM
bsbabcock is offline
post #2 of 14 (permalink) Old 05-12-2014, 07:41 PM
bdbaggr's Avatar
it does get confusing bsb, stage one is a dealer term with pipe, filter and tuner, all else is just an upgrade, owning harleys for years they had their own dealer stages, but from vic all you get is stage one as far as i know... throw money at em and they will call it anything you want. hell you can make up your own stage...and if you ride a vision, you can call it stage coach, that was lame...
bdbaggr is offline
post #3 of 14 (permalink) Old 05-12-2014, 07:44 PM
saddlebag's Avatar
It's all Harley terminology that's been dragged over. You won't hear people who upgrade their other makes/models refer to it like that.
Anyway, from what I've read, Stage 1 is pipes/filter, Stage 2 is cams. Stage X is some combo of porting/polishing intakes, boring head diameters etc.
2011 Cross Roads
saddlebag is offline
post #4 of 14 (permalink) Old 05-12-2014, 08:40 PM
Hemidan's Avatar
Cant we start are own... every new piece(Part) a stage..
some would be on Stage 15+...........
2010 CR - D&D pipes unwrapped / Lloydz Performance Cams / Lloyd'z Idle Air Valve / Lloydz Adjustable Timing System / Lloydz Hi-Flow Air Filter / PCV w/AT / Vintage Mustang Seat w/backrest / Lock Ride Passenger Backrest / Powerlet Handlebar Outlet / Lay down License Bracket / Adjustable Drop Bracket
Avon Velvet Air Cushion Gatlin Grips/DERBY COVER & CAM COVER SET/Beacon LED Headlight Black
Phase 7 L.E.D. 4-1/2" Passing Lamps/Sabertooth Taillight Accents
Hemidan is offline
post #5 of 14 (permalink) Old 05-12-2014, 09:15 PM
ndabunka's Avatar
I like that. In fact, we should probably start higher as well. A Lloyds Air filter on a Victory should probably be called a stage 4 as it makes more than that with that simple $135 mod... Change Pipes and that gives you a Stage 5. Add a tuner and you are at stage 6. Do the cams and you can get to an impossible (for Harleys) 125HP/127TQ so that would make a Harley un-obtainable Stage 7!
It's not just any victory.... It's MY Victory!
2011 Victory Ness Cross Country #120
Ness Thunderheaders
Ness Knurled Highway Pegs/KwelMetal Brackets
Ness Radius laydown license
Chrome CAM Tension Covers
Red Engine Bolts
Madstad System
DIY Garage Door Opener
Victory Chrome Saddle Bag Lid Rails
Küryakyn Upper Fork Shrouds
Küryakyn Lower Fork Covers
Power Commander V Tuner
Power Commander AT-300
Hertz HCX 165s Speakers
JL Audio HX280/4 Bridged 140w
ndabunka is offline
post #6 of 14 (permalink) Old 05-12-2014, 09:16 PM
Loach's Avatar
The "Good Idea" fairy has ked you on the back of the head Hemidan! Hmmm... What shall we call it? V1 Mod.- pipes, air filter! V2 Mod.- timing wheel/cams, PC/tuner! V3 Mod.- Big Bore kit + all of the above?
Just throwing it out there folks!
1999 V92C
2012 XCT
Stroudsburg, PA. U.S.A.
"Life is what YOU make it!"
Loach is offline
post #7 of 14 (permalink) Old 05-12-2014, 11:41 PM
half_crazy's Avatar
People who are serious about performance know that any 'stages' of bullshit won't get the job done.
Harley offers 'stages' thru their Screamin' Eagle catalog. You can get these done at the dealer and they are warrantied. However, almost any aftermarket package will outperform the HD stuff.
Stage 1: pipes/airbox/tuner
Stage 2: the above + cams
Stage 3: all the above + big bore or stroker
Stage 4: all the above + heads/throttle body/injectors
2006 Victory Kingpin
half_crazy is offline
post #8 of 14 (permalink) Old 05-13-2014, 02:55 AM
GatorJoe's Avatar
This is the way I always understood it .. Keep it Simple ..
2017 Indian Chieftain Dark Horse/2005 Dyna Super Glide
GatorJoe is offline
post #9 of 14 (permalink) Old 05-13-2014, 09:11 AM Thread Starter
bsbabcock's Avatar
I'm growing more and more to appreciate cutting through the smoke to the real point.
Yeah these sound pretty much parallel or in line with my early days drooling through the H-D catalog at their performance section.. LOL I said Harley and performance in the same sentence. bwahahaha
Though I knew even as a newb then, the best way to boost a Harley motor is to swap it with a big inch stroked S&S with great heads, strapped to upgraded barnett clutch with a Baker 6-speed tranny.
Which is sad, huh. To make a Harley run, you pretty much replace all the Harley drive-train with something else. But that's another bashing thread. I do try to avoid that, ya know.
Yep.. Same here. I bet a bunch of guys would be surprised that something as awesome as cams, wheel, intake, pipes, tuner and dyno tune would still only be a Stage 2 by this scale. Works for me.. Stage 2 me all day long.
post #10 of 14 (permalink) Old 05-13-2014, 04:39 PM
Oldman47's Avatar
I like the idea of every improvement being a stage. That makes my stock engine with the ATS a stage 1.
When I owned an HD I got the stage 1 air cleaner which really cooled off my right ankle. On an HD your right ankle more or less leans against the air cleaner and the stock one was just to tight to the engine and go very hot. The "stage 1" air cleaner was somewhat taller and had better air flow so it did not get as hot. I never saw any performance improvement but it sure cooled down my ankle.
Oldman47 is offline
