HELP!!! Motor Vibration thru rpm range - Victory Forums - Victory Motorcycle Forum
post #1 of 9 (permalink) Old 10-23-2011, 02:29 PM Thread Starter
Default HELP!!! Motor Vibration thru rpm range
Hi, I have a 2008 Jackpot with 700 miles on it. Recently it seems that the motor is starting to vibrate more and more thru out the rpm range. Mainly it starts around 2200 and goes thru 3500. It even makes my hands go numb and my wifes teeth rattle. It also seems to bog until it gets over 3500 rpms. Is this normal or is there something going wrong inside the motor. Bike has a K&N air filter with vented air box lid and a power commander 3. Rest of bike is stock. I tried searching here and couldn't find anything similar.
Thanks,
Dave
Jackpot RI is offline
post #2 of 9 (permalink) Old 11-07-2011, 05:58 PM Thread Starter
Checked plugs and it seems to be running on the lean side. No color on plug except black at the bottom of the porclain. Could running lean cause this vibration? I'll add that it has been cooler out here. Mid 50's
post #3 of 9 (permalink) Old 11-08-2011, 12:30 PM
Have you changed tires? Look to see if the wheel weights are still on the rims
post #4 of 9 (permalink) Old 11-08-2011, 09:29 PM
If one cylinder isn't getting enough spark and sizzle, it will act sluggish and vibrate. How are the plug wires?
2004 Touring Cruiser
2008 Jackpot Premium
sofakingblue is offline
post #5 of 9 (permalink) Old 11-09-2011, 05:34 PM Thread Starter
Tires are stock. I noticed that the back plug wire is corroded where it plugs into the coil. I purchased this bike last may as a left over. Just hoping that the fuel pump isn't on its way out. I only have 700 miles on it. Its definately running lean.
post #6 of 9 (permalink) Old 11-09-2011, 05:50 PM
Check engine mounting bolts also..Loctite everything on these bikes.
Black8ball is offline
post #7 of 9 (permalink) Old 11-09-2011, 08:57 PM
06vitory's Avatar
Is the bike still under warranty? I have seen power comanders give a few bikes problems. Your sounds like it is running way to lean. So lean that the bike acts like it is running out of fuel. That can cause motor damage. Better get it in to a shop and get checked out. You could try removing the power comander and see if the bike runs better.
2006 Kingpin Deluxe
Stage 1 pipes
Dunlop D407 & D408 tires
06vitory is offline
post #8 of 9 (permalink) Old 11-11-2011, 06:09 AM
philmonger's Avatar
700 miles in 3 years = 1 tank of gas at most per year. My first guess is bad gas followed closely by plugged up fuel injector(s). Try emptying the tank, then fresh gas with some injector cleaner like Gumout or STP....
philmonger is offline
post #9 of 9 (permalink) Old 11-30-2011, 06:12 PM Thread Starter
I found the problem. My intake boot is peeling away from the aluminum base under throttle body. Another 08 intake boot problem... lol
