Info request: rear brake line swap on a steel frame bike - Victory Forums - Victory Motorcycle Forum
post #1 of 4 (permalink) Old 10-24-2011, 04:12 PM Thread Starter
ashmostro's Avatar
Question Info request: rear brake line swap on a steel frame bike
Hey fellow wrenches.
I'm going to be swapping out rear brake lines (both the reservoir/supply and caliper/pressure lines) on my 2011 kingpin due to the conversion I have done from floorboards to vegas Ness-style pegs, in search for more cornering clearance.
I've got the vegas lines, and I have a good idea of where the lines run. Just curious to know how many hours that job has taken others that have had to entirely remove and reinstall both lines. I want to know how much time to set aside.
Thanks
2011 Victory Kingpin 8-Ball
Tach / Dual front discs with Vesrah JL pads / Penske shock / S&S Intake / PCV & autotune / RPW Thor exhaust with homemade custom baffle / Tsukayu leather "Strong" bags / Avon Cobra *Radials* / Ness Vegas Peg Conversion / Ness Vegas driver's seat / Custom T-Apes from BR Custom Cycles
ashmostro is offline
post #2 of 4 (permalink) Old 10-25-2011, 12:29 PM Thread Starter
ashmostro's Avatar
Anyone? Kevinx?
post #3 of 4 (permalink) Old 10-26-2011, 05:30 AM
Vicbuilder's Avatar
Depends on how quick you can get the air bled out. Swapping the lines should only take 15 minutes or so, but getting them bled properly could take a while.
Rylan Vos
The Vic Shop, Inc
(515)-339-4313
Vicbuilder is offline
post #4 of 4 (permalink) Old 10-26-2011, 06:24 AM Thread Starter
ashmostro's Avatar
good to hear. starting the process with a mityvac to get some rbf600 in there (hardest part in my experience is getting it started if you don't have a way to suck the fluid down past the master to get the flow going). then i've got a trick little one-way check valve that allows me to bleed without a helper... cool stuff
thanks man
