Humming from rear wheel - Victory Forums - Victory Motorcycle Forum
post #1 of 8 (permalink) Old 10-24-2011, 04:48 PM Thread Starter
Default Humming from rear wheel
My 12 Vegas has a loud humming sound coming from the area of the rear wheel upon slowing down, maybe 5mph then it stops. It only occurs when I'm slowing to a stop. It's not brake noise because it occurs when the brake isn't engaged. I'm thinking if it was a bearing it would do it all the time. I've owned several dozen cruisers but never have had this issue. I'm thinking it may be the floating rear disc? Any help would be appreciated...
2012 Vegas -D&D slipons, Victory Mini Standard, Tomahawk Bar and rack
2013 GT500
All the toys I need...
USMC341 is offline
post #2 of 8 (permalink) Old 10-24-2011, 05:45 PM
Donzo's Avatar
Bet it's your belt - check for tension and alignment. If you want a quick check to see if it is the belt - spray it with some liquid teflon of rub a bar of soap on it - take it for a ride if the sounds gone....you got the culprit. Very common problem with belt driven bikes.
2010 Crossroads
Midnight Cherry
No Rice
No Pork
Just Beef
Enjoy the miles....we only get so many!
Donzo is offline
post #3 of 8 (permalink) Old 10-24-2011, 06:06 PM Thread Starter
Tension feels ok, but the alignment may not be. Check out the pic I attached. Belt is to one side of the hub, not in center. Is that normal?
2013 GT500
USMC341 is offline
post #4 of 8 (permalink) Old 10-24-2011, 10:04 PM
From my experience, most belt drives ride to the outside of the pulley, probably due to centrifugal force or something. The main thing is to make sure the wheel is aligned per the marks. My 2011 Vegas makes the exact same noise. I have 3000 miles and it has eased a lot. I did adjust my belt in the beginning, and sprayed it with the Teflon spray. Those things helped minimally. Break in time helped the most.
2011 Vegas 8-Ball
Ness Fly Bars
jimmy77611 is offline
post #5 of 8 (permalink) Old 10-24-2011, 10:27 PM Thread Starter
Thanks maybe I'll leave it alone..I was concerned it may be something serious but it appears not.
2013 GT500
USMC341 is offline
post #6 of 8 (permalink) Old 10-25-2011, 11:23 AM
ks_greg's Avatar
According to shop manual, belt is supposed to ride on the inside of the rear pulley when wheel is in forward rotation. Since it's new either swing by the dealer or mention it when it goes in for the first check.
Wichita, Ks.
Prior Rides
'09 Kingpin 8Ball
'06 HD Road King
'06 Vulcan 900 Classic
ks_greg is offline
post #7 of 8 (permalink) Old 10-25-2011, 12:00 PM Thread Starter
Heading out to service now.
Thanks..
2013 GT500
USMC341 is offline
post #8 of 8 (permalink) Old 10-25-2011, 02:31 PM Thread Starter
Ok the verdict is in..normal belt noise. The Vic tech rode it and said yes the belt is tight but they are told to do it that way during break-in. He said the sound will diminish as miles are put on.
I'm good...at least it's normal. I'll get used to it like I did with all the strange noises on my GT500.
Thanks again to all...
2013 GT500
USMC341 is offline
