The magic of auto tune strikes again..... - Victory Forums - Victory Motorcycle Forum
post #1 of 19 (permalink) Old 05-18-2014, 12:04 PM Thread Starter
Send a message via Yahoo to mrtappan Send a message via Skype™ to mrtappan
Default The magic of auto tune strikes again.....
I don't think I'll ever get this bike right.......
Well bikes actually runs now (currently on it about 400 miles from home in Panama City Florida at the Wicked Wheel).
So I hookup the auto tune. First time I checked it cylinder one trims were -20 in most cells and cylinder two was +20 in most cells. So I checked my plugs to see what they looked like. Slightly ashy on the tip but not pitted or damaged from knock.
All I can think of is a possible vacuum leak. Bike runs OK with a donated map from Rylan. What's funny is with the busted PCV the auto tune actually gave believable adjustments like +/- 1-8 or so.
Fix one problem create another with this bike. The 100 cubic inch victories seem to be the last model they built worth a damn
Current toys:
2013 Victory Hardball - VM1DR cams, Lloydz filter, timing wheel, PCV-AT, 1/4 turn throttle, modified pipes
2008 Yamaha Warrior -Churchkey intake, V&H Bigshots
2007 Scion TC 5spd
1997 F150 -used to pull my car hauler
1989 Nissan Hardbody -absolutely indestructible
1968 Coupe Deville -all black, so nice
mrtappan is offline
post #2 of 19 (permalink) Old 05-18-2014, 08:51 PM
raptout's Avatar
maybe try spraying a little brake cleaner around the TB to checks for air leaks?
2008 Vegas 8-Ball
Victory Stage 1
raptout is offline
post #3 of 19 (permalink) Old 05-18-2014, 09:18 PM Thread Starter
I already bought a.can but haven't checked.yet. changed to a generic map way richer than Rylan's and seems to work better. Rylan's map had a lot of negative cells which I thought was weird but I tried it anyways. This map is all positive cells.
Current toys:
2007 Scion TC 5spd
mrtappan is offline
post #4 of 19 (permalink) Old 05-18-2014, 11:07 PM
BP6666VR's Avatar
Why Brake Cleaner on the vacuum hoses?? Please explain out of interest?
Cross Country Tour 2014 [B]
BP6666VR is offline
post #5 of 19 (permalink) Old 05-19-2014, 01:59 AM
If you have an air leak and spray a flammable aerosol instead of sucking air it sucks fuel and runs smoother/different.
Rlanda is offline
post #6 of 19 (permalink) Old 05-19-2014, 02:42 AM
Oldman47's Avatar
I agree Rlanda but brake cleaner can quickly ruin paint. I would try something a bit less destructive myself.
Oldman47 is offline
post #7 of 19 (permalink) Old 05-19-2014, 02:51 AM
as would I. If I recall we would use an oxycetaline torch with no flame back in high school.
Rlanda is offline
post #8 of 19 (permalink) Old 05-19-2014, 02:55 AM
half_crazy's Avatar
It would be worth the trip to take the bike to KevinX in Florida (3-1/3 hours), or take it to Kyle at the SE Vic Rally in Helen, GA (6-1/2 hours).
Let's face it... what you're doing isn't working. Get it checked out. Get it tuned. Go ride and enjoy it.
2006 Victory Kingpin
half_crazy is offline
post #9 of 19 (permalink) Old 05-19-2014, 03:09 AM
Motorbikerx's Avatar
make sure ya aint got a spark leak anywhere or youll go up like a bomb!
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
Motorbikerx is offline
post #10 of 19 (permalink) Old 05-19-2014, 05:55 AM
Tarzan's Avatar
Is Kevinx new shop up and running already?
You guys on the East Coast have it good.
'14 Ness XC
Tarzan is offline
