Fuel Injectors - Victory Forums - Victory Motorcycle Forum
post #1 of 13 (permalink) Old 05-19-2014, 06:39 PM Thread Starter
Default Fuel Injectors
Does anybody have any information on our fuel injectors? I am speaking specifically of a 2006 100 CI bike. I am working on a turbo system and would like to figure out what kind of flow rate the stock injectors offer and if they are high Z or low Z. I could just measure the impedance i suppose but still that wont tell me what their flow rate is. Would also like to know if there is anything out there for higher flow injectors that will fit since i cant find any info on them. Victory PN is 1253405 but that is about all the info i get.
Thanks!
moparx12 is offline
post #2 of 13 (permalink) Old 05-19-2014, 09:42 PM
Speeddemon3579's Avatar
Might want to call one of the builders. No luck on the web.
2000 V92SC
Middle Tenn
it ain't stock...
2000 V92SC
Rock Island,TN
If I can't buy it, I make it.
Just Getting Started
Speeddemon3579 is offline
post #3 of 13 (permalink) Old 05-20-2014, 08:43 AM
Rylan at the Vic shop did a turbo he might know
http://thevicshop.com/Contact.html
post #4 of 13 (permalink) Old 05-20-2014, 04:58 PM Thread Starter
Thanks guys. I sent an email off to Lloyd because i have spoken with him before. If he gets back to me that will be great if not i may try to contact one of the other guys.
moparx12 is offline
post #5 of 13 (permalink) Old 05-20-2014, 10:29 PM
It appears we run 1st gen GM Delphi injectors. Not sure which ones but.... One step closer
2000 V92SC
Middle Tenn
it ain't stock...
2000 V92SC
Rock Island,TN
post #6 of 13 (permalink) Old 05-20-2014, 10:46 PM
I know the fuel system is 40# but what are the injectors?
2000 V92SC
Middle Tenn
it ain't stock...
2000 V92SC
Rock Island,TN
post #7 of 13 (permalink) Old 05-21-2014, 03:33 AM
Oldman47's Avatar
The fuel system runs 50 psi, not 40. I hope that means something to you. To me it is just a way of knowing if the fuel pump is working right.
Oldman47 is offline
post #8 of 13 (permalink) Old 05-21-2014, 08:20 AM
I keep doing that. Thanks for the reminder.
2000 V92SC
Middle Tenn
it ain't stock...
2000 V92SC
Rock Island,TN
post #9 of 13 (permalink) Old 05-21-2014, 08:18 PM Thread Starter
Thanks for that info, yes that will be important! So i went out and yanked one of the injectors off. I am currently trying to figure out specs on it and i am having a hard time even with the injector right in front of me.
The numbers on the side are:
0 280 156 140
And then near the clip, there is a printed number (the latter was molded in the plastic). That one is 127511
moparx12 is offline
post #10 of 13 (permalink) Old 05-21-2014, 09:08 PM
Default Car parts?
Maybe you could contact Summit Racing. They sell hi-performance injectors for cars. Send them the numbers, maybe they match a Camero or something GM.
Buckeye, Arizona(USA) 2011 Victory Cross Roads, Black police bag guards, black engine guards, black handle bars, Triumph Tiger mirrors, Triumph hand grips, set speedo/tach back 5" , adjustable timing wheel, Lloyzz Fuel Programmer III & air filter. Modified exhaust, made stock into 2 into 1. MRA windshield, Rotated front fender forward,relocated ignition switch, Bad Ace Fuel Tank Risers, Fat front tire.
Speedblue is offline
