Oil change - Victory Forums - Victory Motorcycle Forum
post #1 of 8 (permalink) Old 05-21-2014, 07:47 PM Thread Starter
Default Oil change
Can anybody help me out? I have a xct 2012. I'm changing my oil & found two washers for the filter. One rubber & one metal. What goes on the shaft first?
Tony is offline
post #2 of 8 (permalink) Old 05-21-2014, 07:53 PM
Ghost_Rider's Avatar
The metal one is probably for the drain plug. The oil filter should already have an o-ring on it
2003 V92C
Wrapped RPW Slash pipes
K&N air filter
Stebel Nautilus
Viking saddlebags
16" apes
Ghost_Rider is offline
post #3 of 8 (permalink) Old 05-21-2014, 08:01 PM Thread Starter
Default Oil change
It also had one for the plug.
Tony is offline
post #4 of 8 (permalink) Old 05-21-2014, 08:25 PM
Did you get the victory oil and filter?
2003 V92C
K&N air filter
Stebel Nautilus
Viking saddlebags
16" apes
post #5 of 8 (permalink) Old 05-21-2014, 08:27 PM
Judge Redd's Avatar
I guess I could be mistaken- but I'm just not aware of any washers for the oil filter. These are small washers- not the big ole 3 inch +/- O ring? Maybe post a pic.
If you have an O ring on the floor- either the OLD O ring separated from the filter housing when you removed it, or the new oil filter came apart? Obviously make sure the engine surface is 100% free of any old O ring fragments.
I think if I found my new oil filter O ring on the floor, or otherwise separated from the housing- I would be getting a replacement.
Remember to coat the new O ring with some clean oil before installing it.
The oil drain plug washer (the crush washer) is copper-y looking.
2014 Judge(Havasu Red) PC-V - ATS(+4) - RPW Boom Sticks - HOHVM1-DR cams - Torque Tubes (dyno sheet) 1/4 turn throttle - OPT7 LED headlight kit - OEM bags, backrest, and W/S
Judge Redd is offline
post #6 of 8 (permalink) Old 05-21-2014, 09:14 PM Thread Starter
Default Oil change
Thanks to all. Got it done.
Tony is offline
post #7 of 8 (permalink) Old 05-21-2014, 09:37 PM
VegasVic's Avatar
There are no washers for the filter. The two different washers are for different year drain plugs.
You need the metal one.
11 XC
VegasVic is offline
post #8 of 8 (permalink) Old 05-22-2014, 10:17 AM
pgreen7436's Avatar
Default washers
The oil change kit I bought from the dealer (never again) had a metal gasket about 2.5" in dia. All I could assume since it says it's for the V92 engine, is that there is something on those bikes that need that gasket. I did get two filler plug gaskets though. Sweet! I'll change oil at about 1000mi and put Rotella T in it and get a Wix(?) oil filter.
2013 Victory Cross Country Tour - Boardwalk Blue
Round Rock, Texas
pgreen7436 is offline
