Exhaust pipe red hot - Victory Forums - Victory Motorcycle Forum
post #1 of 5 (permalink) Old 05-22-2014, 10:27 PM Thread Starter
Default Exhaust pipe red hot
Installed top filter in my Vision today. Road to work and the rear cylinder pipe was red hot. Should I unplug o2s. I tried to install power commander but those injector plugs suck. I have a Stage 1 download in the bike already. Would not think it would run that lean to make the pipe glow ?
My ride
2013 Vision Touring. Shelbyville IL
Lloyds 116 big bore
Lloyds timing wheel set at plus 2
Lloyds adjustble intake
Lloyds HP cams
Lloyds quarter turn throttle
PCV 5
Ness Big Honkers
Lloyds Vision intake plate
Lloyds variable clutch
Heads worked over
Built and tuned by Rylan Vos at The Vic Shop
Adel ia.
136HP 139FTLBS
new vic rider is offline
post #2 of 5 (permalink) Old 05-23-2014, 07:13 AM
soofle616's Avatar
Not much else that I can think of that would make a pipe that hot except extreme lean condition. I would definitely do SOMETHING before riding it anymore though. EGT's that high could result in some real damage.
2013 Cross Roads LE
I'm on the app store! Check out Solitaire: Slide it's free!
soofle616 is offline
post #3 of 5 (permalink) Old 05-23-2014, 10:44 AM Thread Starter
My lovely wife got out of bed at 5am and brought me the stock plate and the tools to take it back to stock. What a gal. Going to wait till I go to the Vic Shop and have him install everything and dyno tune it.
My ride
Lloyds 116 big bore
Lloyds HP cams
PCV 5
Ness Big Honkers
Heads worked over
Adel ia.
136HP 139FTLBS
post #4 of 5 (permalink) Old 05-23-2014, 12:23 PM
Roadrocket's Avatar
Smart move! As Clint Eastwood once said, "A man has got to know his limitations."
The Truth is Often Painful
2011XC
Roadrocket is offline
post #5 of 5 (permalink) Old 05-23-2014, 11:39 PM
Yeah. Thanks to the EPA mandates which are really ridiculous in my humble opinion; all motorcycles from the factory are set as lean as possible. Even the Stage 1 download is the same kind of lean. You are correct in unplugging the O2 sensors.
It can be a bear to install the injector plugs for the PC-V. If you don't feel comfy doing it; it's definitely ok to let someone who does it for a living do it. I personally would have them also install the Auto Tune unit. It will pay for itself over time every time you change something like exhaust, cams, air filter, etc. and let your bike run much cooler which on a Vision is an issue during the hot months.
