Belt drive cover - Victory Forums - Victory Motorcycle Forum
post #1 of 4 (permalink) Old 05-24-2014, 11:34 AM Thread Starter
Default Belt drive cover
I have a 2013 vegas. Lowered it 1.5 inches and get the belt rub going over large bumps. Got an open belt cover on the way. Was wondering if it's ok to take the stick belt cover off and ride like that until the new one comes? Belt isn't damaged at all from the rubbing. Just makes a slight squeal.
THLB350 is offline
post #2 of 4 (permalink) Old 05-24-2014, 12:34 PM
dtmmil's Avatar
should be fine just be aware its open
currently bikeless
2012 Cross Country(Imp blue)
Hawley MN(sold)
dtmmil is offline
post #3 of 4 (permalink) Old 05-25-2014, 03:34 PM
I had the same problem with a lowering bracket. It also is rubbing inside of the primary cover. I ground a couple of the notches down on the inside for more clearance. But it still might rub with the factory mono shock cuz its too spongy. Especially if u go 2 up. Best way to solve that is to buy a better shock like a progressive
2012 hammer 8 ball
Lloydz torque tubes
rpw big slash 2-1exhaust
Lloydz cams
pc5
Burleigh handlebars
drag specialties seat
progressive 1 inch lower coil over shock
113 hp 125 tq
blackbetty12 is offline
post #4 of 4 (permalink) Old 05-25-2014, 06:14 PM
take cover off and grind this spot do not grind threw
