torque wrench specs front wheel - Victory Forums - Victory Motorcycle Forum
post #1 of 5 (permalink) Old 11-01-2011, 06:19 PM Thread Starter
Smile torque wrench specs front wheel
Hi Guys, I am doing front wheel conversion on 2011 vegas 8 ball, 21 to 18 inch I was wondering If anyone had the tension settings for front axle nut, fork pinch bolts and rotor bolts. I dont have a service manual yet............Thanks in Advance
meanmother57 is offline
post #2 of 5 (permalink) Old 11-02-2011, 12:22 PM
Stretch15's Avatar
I don't have the manual in front of me... I can look when I get home tomorrow. But the pinch bolts aren't much... 18 ft.lbs I believe. The main axle just needs to be snugged up good and the pinch bolts do the rest. Ill look tomorrow.
'06 Ness Jackpot
S&S Intake
05 Hammer Map
Slash Exhaust
That's it...for now
Stretch15 is offline
post #3 of 5 (permalink) Old 11-04-2011, 01:45 AM Thread Starter
Default torque wrench spec front wheel
Thanks for the replie Stretch, I guess the rotor bolts would also be 18 ft lb are same diameter as pinch bolts, axle must be around 40 ft lb or so, If you could check in your manual would be appreciated..........Just to be sure I dont over tension them................Thanks.......
post #4 of 5 (permalink) Old 11-04-2011, 11:33 AM
Stretch15's Avatar
Rotor Bolts 30Nm/ 22ft/lbs
Main Axle 47.5 Nm / 35fl/lbs
Pinch Bolts 24Nm/ 18ft/lbs
(Retorque after initial torque)
Hope that helps.
'06 Ness Jackpot
S&S Intake
05 Hammer Map
Slash Exhaust
That's it...for now
post #5 of 5 (permalink) Old 11-04-2011, 03:08 PM Thread Starter
Thanks Stretch, I will have to get myself a service manual so Im not flying blind doing things to bike.Plan on doing cams next year after bike out of warranty..................
